General |
Type |
Thin client |
Product Form Factor |
Tower |
Built-in Devices |
Speaker |
Embedded Security |
Trusted Platform Module (TPM 1.2) Security Chip |
Localisation |
Language: English / region: United Kingdom |
Processor / Chipset |
CPU |
AMD R-series RX427BB / 2.7 GHz |
Max Turbo Speed |
3.6 GHz |
Number of Cores |
Quad-Core |
CPU Qty |
1 |
Max CPU Qty |
1 |
Cache Memory |
Installed Size |
L2 Cache - 4 MB |
Cache Per Processor |
4 MB |
RAM |
Installed Size |
8 GB / 16 GB (max) |
Technology |
DDR3L SDRAM |
Effective Memory Speed |
1600 MHz |
Rated Memory Speed |
1600 MHz |
Memory Specification Compliance |
PC3L-12800 |
Form Factor |
SO-DIMM 204-pin |
Slots |
2 (Total) / 0 (empty) |
Features |
Dual channel memory architecture |
Configuration Features |
2 x 4 GB |
Hard Drive |
Type |
Flash - M.2 |
Capacity |
1 x 32 GB |
Optical Storage |
Type |
No optical drive |
Monitor |
Monitor Type |
None. |
Graphics Controller |
Graphics Processor |
AMD Radeon HD 9000 |
Video Interfaces |
DisplayPort |
Networking |
Data Link Protocol |
Ethernet, Fast Ethernet, Gigabit Ethernet |
Features |
Wake on LAN (WoL), PXE support |
Expansion / Connectivity |
Slots |
1 (total) / 0 (free) x M.2 Card , 1 (total) / 1 (free) x PCIe 3.0 x16 (x8 mode) |
Interfaces |
6 x USB 2.0 (2 front, 4 rear) , 3 x USB 3.0 (2 front, 1 internal) , 4 x DisplayPort , 2 x PS/2 keyboard / mouse , 2 x serial , 1 x parallel , 1 x LAN (Gigabit Ethernet) , 2 x headphones/microphone (2 in front) , 1 x audio line-in , 1 x audio line-out |
Miscellaneous |
Theft/Intrusion Protection |
Security lock slot (cable lock sold separately) |
Security Slot Type |
Kensington security slot |
Compliant Standards |
FCC Class B certified, TUV GS, VCCI, UL 1950, CSA 22.2 No. 950, EN55022 Class B, low halogen |
Power |
Device Type |
Power adapter |
Nominal Voltage |
AC 120/230 V (50/60 Hz) |
Power Provided |
85 Watt |
Operating System / Software |
OS Provided |
Windows 10 IOT Enterprise for Thin Clients 64-bit Edition English |
Environmental Standards |
ENERGY STAR Certified |
Yes |
Manufacturer Warranty |
Service & Support |
Limited warranty - parts and labour - 3 years |
Dimensions & Weight |
Width |
6.7 cm |
Depth |
22.1 cm |
Height |
24 cm |
Weight |
1.8 kg |
Environmental Parameters |
Min Operating Temperature |
10 °C |
Max Operating Temperature |
40 °C |
Humidity Range Operating |
10 - 90% (non-condensing) |
