HP T730 AMD RX427BB 8GB 32GB Windows Embedded Ind 10 Pro
£1,019.20
Delivery:
Key features
  • Create an efficient, multi-monitor workspace with DisplayPort connections for up to four UHD/4K displays.
  • Harness the power of AMD’s latest generation quad-core APU with Turbo Core technology to run full VDI and local applications to four displays.
  • Streamline deployments, enhance the user experience, and enable smooth device management with HP’s exclusive software.
  • Support your business now and in the future with a range of current and legacy ports and a PCI Express x4 low profile expansion slot.
  • Processor Type: RX427BB
  • Operating System: Windows 10 IoT Enterprise
  • Installed Memory: 8GB
  • Hard Drive Capacity: 32GB
  • Storage Type: Flash
Product codes
Goodbye add-ons, extras, and optional features. The HP t730 Thin Client, HP's most powerful desktop thin client, is ready to deploy in demanding environments right out of the box with an AMD quad-core processor, maximum interfaces, OS and ISV choices, and native support for 4 UHD/4K displays.
Product Description HP t730 - tower - RX427BB 2.7 GHz - 8 GB - 32 GB
Type Thin client - tower
Localisation Language: English / region: United Kingdom
Processor 1 x AMD RX427BB 2.7 GHz (3.6 GHz) (Quad-Core)
Cache Memory 4 MB L2 Cache
Cache Per Processor 4 MB
RAM 8 GB (installed) / 16 GB (max) DDR3L SDRAM - PC3-12800
Hard Drive 1 x flash 32 GB - M.2
Optical Storage No optical drive
Graphics Controller AMD Radeon HD 9000
Networking GigE
Power AC 120/230 V (50/60 Hz)
OS Provided Windows 10 IOT Enterprise
Dimensions (WxDxH) 6.7 cm x 22.1 cm x 24 cm
Weight 1.8 kg
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
HP T730 AMD RX427BB 8G...
£1,019.20
