General |
Type |
Thin client |
Product Form Factor |
Tower |
Built-in Devices |
Speaker |
Embedded Security |
Trusted Platform Module (TPM 1.2) Security Chip |
Localisation |
Language: English / region: United Kingdom |
Processor / Chipset |
CPU |
AMD R-series RX427BB / 2.7 GHz |
Max Turbo Speed |
3.6 GHz |
Number of Cores |
Quad-Core |
CPU Qty |
1 |
Max CPU Qty |
1 |
Cache Memory |
Installed Size |
L2 Cache - 4 MB |
Cache Per Processor |
4 MB |
RAM |
Installed Size |
8 GB / 16 GB (max) |
Technology |
DDR3L SDRAM |
Effective Memory Speed |
1600 MHz |
Form Factor |
SO-DIMM 204-pin |
Slots |
2 (Total) / 0 (empty) |
Features |
Dual channel memory architecture |
Configuration Features |
2 x 4 GB |
Hard Drive |
Type |
Flash - M.2 |
Capacity |
1 x 64 GB |
Features |
Multi-level cell (MLC) |
Optical Storage |
Type |
No optical drive |
Monitor |
Monitor Type |
None. |
Graphics Controller |
Interface Type |
PCIe 3.0 x8 |
Multi-GPU Configuration |
1 single GPU card / integrated GPU |
Graphics Processor |
AMD FirePro W2100 / AMD Radeon HD 9000 |
Video Memory |
2 GB DDR3 SDRAM |
Video Interfaces |
DisplayPort |
Max Monitors Supported |
6 |
Input Device |
Type |
Mouse, keyboard |
Keyboard |
Localization & Layout |
UK |
Mouse |
Mouse Name |
HP USB Mouse |
Technology |
Optical |
Interface |
USB |
Networking |
Data Link Protocol |
Ethernet, Fast Ethernet, Gigabit Ethernet |
Features |
Wake on LAN (WoL), PXE support |
Expansion / Connectivity |
Slots |
1 (total) / 0 (free) x M.2 Card , 2 (total) / 0 (free) x SO-DIMM 204-pin , 1 (total) / 0 (free) x PCIe 3.0 x16 - low-profile (x8 mode) |
Interfaces |
6 x USB 2.0 (2 front, 4 rear) , 3 x USB 3.0 (2 front, 1 internal) , 6 x DisplayPort , 2 x PS/2 keyboard / mouse , 2 x serial , 1 x parallel , 1 x LAN (Gigabit Ethernet) , 2 x headphones/microphone (2 in front) , 1 x audio line-out , 1 x audio line-in |
Miscellaneous |
Theft/Intrusion Protection |
Security lock slot (cable lock sold separately) |
Security Slot Type |
Kensington security slot |
Compliant Standards |
FCC Class B certified, TUV GS, VCCI, EN 60950, UL 1950, CSA 22.2 No. 950, EN55022 Class B, low halogen |
TAA Compliant |
Yes |
Power |
Device Type |
Power adapter |
Nominal Voltage |
AC 120/230 V (50/60 Hz) |
Power Provided |
85 Watt |
Operating System / Software |
OS Provided |
Windows 10 IOT Enterprise English |
Software |
Citrix ICA, HP Universal Print Driver, HP Remote Graphics Software, Microsoft Windows Media Player 12, HP Device Manager, Citrix Receiver, VMware Horizon View, Citrix HDX, HP Velocity, Microsoft RemoteFX, Microsoft Internet Explorer 11, VMware PCoIP, HP ThinUpdate, HP True Graphics, HP Easy Shell |
Environmental Standards |
ENERGY STAR Certified |
Yes |
Manufacturer Warranty |
Service & Support |
Limited warranty - parts and labour - 3 years |
Dimensions & Weight |
Width |
6.7 cm |
Depth |
22.1 cm |
Height |
24 cm |
Weight |
1.8 kg |
Environmental Parameters |
Min Operating Temperature |
10 °C |
Max Operating Temperature |
40 °C |
Humidity Range Operating |
10 - 90% (non-condensing) |
