HP T730 AMD RX427BB 8GB 64GB Windows Embedded Std 7 Pro
£1,045.22
Delivery:
Key features
  • Create an efficient, multi-monitor workspace with DisplayPort connections for up to four UHD/4K displays.
  • Harness the power of AMD’s latest generation quad-core APU with Turbo Core technology to run full VDI and local applications to four displays.
  • Streamline deployments, enhance the user experience, and enable smooth device management with HP’s exclusive software.
  • Support your business now and in the future with a range of current and legacy ports and a PCI Express x4 low profile expansion slot.
Product codes
Goodbye add-ons, extras, and optional features. The HP t730 Thin Client thanks to quad UHD/4K displays natively, is ready to deploy in demanding environments right out of the box with an AMD quad-core processor, maximum interfaces, and OS and ISV choices.
Product Description HP t730 - tower - RX427BB 2.7 GHz - 8 GB - 64 GB - UK
Type Thin client - tower
Localisation Language: English / region: United Kingdom
Processor 1 x AMD RX427BB 2.7 GHz (3.6 GHz) (Quad-Core)
Cache Memory 4 MB L2 Cache
Cache Per Processor 4 MB
RAM 8 GB (installed) / 16 GB (max) - DDR3L SDRAM - PC3-12800
Hard Drive 1 x flash 64 GB - M.2
Optical Storage No optical drive
Graphics Controller PCIe 3.0 x8 - AMD FirePro W2100
Video Memory 2 GB DDR3 SDRAM
Networking GigE
Keyboard UK
Power AC 120/230 V (50/60 Hz)
OS Provided Microsoft Windows Embedded Standard 7P 64-bit
Dimensions (WxDxH) 6.7 cm x 22.1 cm x 24 cm
Weight 1.8 kg
Environmental Standards ENERGY STAR Qualified
Manufacturer Warranty Limited warranty - parts and labour - 3 years
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
HP T730 AMD RX427BB 8G...
£1,045.22
