HP Tango Smart Home Printer
£131.98
Delivery:
Key features
  • Easily print everyday documents from your smartphone.
  • Get connected and start printing fast with seamless Wi-Fi® setup from your smartphone.
  • Print photos from your smartphone for free, with Tango and HP Instant Ink.
  • Save on ink and get it automatically delivered to your door. Ink cartridges and delivery costs included in your monthly plan price.
Product codes
Built to match the way you live and designed to use with the HP Smart app, Tango helps you stay a step ahead by connecting and printing from any device, anywhere.
Dynamic security enabled printer. Intended to be used with cartridges using only HP original electronic circuitry. Cartridges with modified or non-HP electronic circuitry may not work, and those that work today may not work in the future.
Product Description HP Tango - printer - colour - ink-jet
Printer Type Photo printer - ink-jet - colour
Weight 3.08 kg
Localisation Western Europe, United Kingdom, Ireland, Nordics, Baltic Region
Inkjet Technology HP Thermal Inkjet
Ink Palette Supported (Colours) 4-ink - cyan, magenta, yellow, black
Media Size Class A4/Legal
Max Media Size Legal (216 x 356 mm), A4 (210 x 297 mm)
Min Media Size (Custom) 76 mm x 127 mm
Max Media Size (Custom) 216 mm x 356 mm
Print Speed Up to 20 ppm - black draft - A4 (210 x 297 mm)/ANSI A (Letter) (216 x 279 mm) , Up to 11 ppm - black (ISO) - A4 (210 x 297 mm)/ANSI A (Letter) (216 x 279 mm) , Up to 19 ppm - colour draft - A4 (210 x 297 mm)/ANSI A (Letter) (216 x 279 mm) , Up to 8 ppm - color (ISO) , Up to 0.62 ppm - colour photo - 100 x 150 mm
Max Resolution (B&W) 1200 x 1200 dpi
Max Resolution (Colour) 4800 x 1200 dpi
Interface Wi-Fi(n), Bluetooth LE
Processor 360 MHz
RAM Installed (Max) 256 MB (256 MB) - DDR3 SDRAM
Language Simulation HP PCL 3 GUI
Media Type Labels, plain paper, photo paper, cards, recycled paper, thick paper, light-weight paper, glossy paper, matte paper
Total Media Capacity 50 sheets
Media Handling 50-sheet input tray
Monthly Duty Cycle (max) 500 pages
Recommended Monthly Volume 100 - 300 pages
Networking Print server
Printer Features Print from mobile device, Auto Power Off
Power AC 120/230 V
System Requirements Microsoft Windows 7 / 8 / 8.1 / 10, Apple OS X 10.11 El Capitan, Apple macOS Sierra 10.12, Apple macOS High Sierra 10.13
Enclosure Colour Wisp grey
Manufacturer Warranty 1-year warranty
Dimensions (WxDxH) 37.7 cm x 20.6 cm x 9.1 cm
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
HP Tango Smart Home Pr...
£131.98
