HP Thunderbolt Docking Station 120W
£220.48
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Connect a single USB-C™ cable to your notebook to access a wired network, data, video, and charging with a dock that supports both HP and non-HP Thunderbolt™ and USB-C™ notebooks.
  • Help IT easily secure and remotely manage a wide range of HP notebooks and the dock with advanced network manageability features built into the dock, including WoL and MAC Address Pass-Through in all power states and PXE Boot.
  • Reclaim your work area with this space-saving centerpiece that helps create a clean desk. Its elegant, black, rounded design with smooth accents changes everything you thought you knew about docks.
  • Secure the base dock to a desk, table or your notebook through the lock slot with an optional HP lock.
  • See every color and detail of your projects with a superfast connection to dual external 4K displays as soon as you plug your notebook into the dock.
  • Take calls without a headset with our first Thunderbolt™ dock with an audio conferencing solution. The optional HP TB Dock Audio Module attaches vertically to the dock with no cabling.
  • Type: Docking Stations
  • Colour: Black
  • Stock Status: In Stock
Product codes
Reinvent docking and boost productivity with our most versatile Thunderbolt dock, the small, sophisticated HP Thunderbolt Dock G2. Designed for workspace flexibility and network manageability, it delivers USB-C device connectivity and optional integrated audio.
Product Description HP Thunderbolt Dock G2 - docking station - VGA, DP, 2 x DP
Product Type Docking station
Video Interfaces VGA, DP, 2 x DP
Dimensions (WxDxH) 9.8 cm x 9.8 cm x 6.9 cm
Weight 800 g
Localisation English / United Kingdom
Networking Ethernet
Power Power adapter 120 Watt
Manufacturer Warranty 1-year warranty
Designed For Elite x2; EliteBook 735 G5, 735 G6, 745 G5, 745 G6, 755 G5, 830 G5, 840 G6, 840r G4, 850 G5, 850 G6; EliteBook x360; Mobile Thin Client mt45; ProBook 430 G6, 445r G6, 44X G6, 455r G6, 45X G5, 45X G6, 640 G5, 64X G4, 650 G4, 650 G5; ProBook x360; Spectre x360; ZBook 14u G5, 14u G6, 15u G5, 15u G6
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
HP Thunderbolt Docking...
£220.48
