HP Ultra Slim Docking Station - 2013
£148.23
Hurry, only 1 left in stock!
Delivery:
Standard: 1-3 working days
Express: Delivered tomorrow
Express Delivery:
  • 00 h
  • 00 m
  • 00 s
Key features
  • Four USB 3.0 ports offer high-speed connectivity to the USB devices you use most. USB 3.0 reduces the time required for data transmission (vs. USB 2.0), is backward compatible with USB 2.0, and is bi-directional.
  • Get high-speed connectivity to the USB devices you use most with four USB 3.0 ports, which reduce the time required for data transmission (vs. USB 2.0), are backward compatible with USB 2.0, and bi-directional.
  • Secure the connected notebook to the dock with the optional HP Docking Station Cable Lock (sold separately).
  • Device Type: Laptop
  • Device Screen Size: [N/A]
  • Stock Status: In Stock
Product codes
Designed exclusively for ultraslim HP EliteBook Notebook PCs, the HP UltraSlim Docking Station expands display, network, and device connectivity so you can be more productive throughout the day-all through a simple one-click slide-in side dock.
Product Description HP UltraSlim Docking Station 2013 - docking station - VGA, 2 x DP
Product Type Docking station
Video Interfaces VGA, 2 x DP
Dimensions (WxDxH) 36.8 cm x 10.7 cm x 4.4 cm
Weight 760 g
Localisation English / United Kingdom
Power Power adapter - external 65 Watt
Designed For EliteBook 735 G5, 735 G6, 745 G4, 745 G5, 745 G6, 755 G4, 755 G5, 820 G4, 830 G5, 830 G6, 840 G4, 840 G5, 840 G6, 840r G4, 850 G4, 850 G5, 850 G6; Mobile Thin Client mt45; ProBook 640 G5, 64X G3, 64X G4, 650 G4, 650 G5, 65X G3; Spectre x360; ZBook 14u G4, 14u G5, 14u G6, 15u G4, 15u G5, 15u G6
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
HP Ultra Slim Docking...
£148.23
