HP USB-C to DisplayPort Adapter
£36.00
11 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Connect the adapter to your tablet or notebook’s USB-C™ port and broadcast to a monitor, projector or TV through the DisplayPort connection.
  • Rest easy with a one-year limited warranty.
  • Take the small adapter with you in your device’s carrying case for quick projection wherever you work.
  • Stock Status: In Stock
Product codes
Put your notebook or tablet's high-definition video content up on the big screen with the HP USB-C to DP Adapter, which enables connection to an external display, TV or projector.
Product Description HP - external video adapter
Device Type External video adapter
Bus Type USB-C
Interfaces DisplayPort
Dimensions (WxDxH) 2.36 cm 1.52 cm
Length 18 cm
Designed For HP 340S G7; Chromebook 11A G6; Elite Slice G2; Elite x2; EliteBook 735 G6, 745 G6, 840 G6, 850 G6; EliteBook x360; EliteDesk 800 G5; EliteOne 800 G5; Mobile Thin Client mt45; ProBook 430 G6, 440 G6, 450 G6, 640 G5, 650 G5; ProBook x360; ProDesk 600 G5; ZBook 14u G6, 15 G6, 15u G6, 17 G6
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
HP USB-C to DisplayPor...
£36.00
