HP USB Mouse $
HP USB Mouse $
£12.16
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Optical tracking - Reduce sticking and constant cleaning with optical tracking – a system that works through light with less moving parts for greater durability than ball-based mice.
  • The optical sensor within the HP USB Optical Scroll Mouse employs a scan rate of 800dpi and enables crisp motion without a mouse pad, ball or roller.
  • Users benefit from a smooth, contoured shape that fits both hands – and a wheel that functions as a third button.
  • Wired / Wireless: Wired
  • Compatibility: PC
  • Stock Status: In Stock
Product codes
Bundle deals (1)
ANTIBACTERIAL WIPES
ANTIBACTERIAL WIPES
= £15.65
Save £1.50
Utilizing the latest optical sensing technology, the HP USB Optical Scroll Mouse records precise motion over a variety of surfaces without a mouse pad.
Product Description HP - mouse - USB
Device Type Mouse
Connectivity Technology Wired - USB
Localisation English / United Kingdom
Movement Detection Technology Optical
Buttons Qty 3
Movement Resolution 800 dpi
Features Scrolling
Designed For HP 260 G3, 280 G4, 285 G3, 290 G3, t430, t628; Desktop Pro 300 G3, Pro A 300 G3, Pro A G2, Pro G3; Elite Slice for Meeting Rooms G2, Slice G2; EliteDesk 705 G3, 705 G4, 705 G5, 800 G4, 800 G5; EliteOne 1000 G1, 1000 G2, 800 G3, 800 G5; RP9 G1 Retail System; Workstation Z1 G5, Z2, Z4 G4, Z6 G4, Z8 G4
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
HP USB Mouse $
£12.16
