HP v196 18.5" LED Monitor 1366x768
£81.27
20 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Enjoy quality front-of-screen performance for all of your daily tasks.
  • Mount your HP Desktop Mini 2602 directly behind the display for an integrated, affordable all-in-one.
  • Reduce power consumption and help lower your costs with an energy-efficient design.
  • Diagonal Size: 18.5in
  • Max Resolution: 1366 x 768
  • Response Time: 5ms
  • Speakers: None
  • Interfaces: DVI, VGA (HD-15)
Product codes
Get quality presentation features at a price point that doesn't break the bank with the HP V197 47 cm (18.5") Monitor, a sleek, thin-profile monitor in a compact, space-saving screen size with an unbelievably low price point.
Product Description HP v197 - LED monitor - 18.5"
Device Type LED-backlit LCD monitor - 18.5"
Panel Type TN
Aspect Ratio 16:9
Native Resolution 1366 x 768 at 60 Hz
Pixel Pitch 0.3 mm
Brightness 200 cd/m²
Contrast Ratio 600:1 / 5000000:1 (dynamic)
Response Time 5 ms (On/Off)
Input Connectors DVI-D, VGA
Display Position Adjustments Tilt
Screen Coating Anti-glare
Colour Black
Dimensions (WxDxH) - with stand 44.14 cm x 21.81 cm x 33.86 cm
Weight 2.6 kg
Localisation English / United Kingdom
Environmental Standards ENERGY STAR Qualified
Compliant Standards Plug and Play, TUV, GS, CB, CCC
Manufacturer Warranty 1-year warranty
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
HP v196 18.5" LED Moni...
£81.27
