HP V214a 1920 x108 LED 20.7" Monitor
£94.32
Hurry, only 2 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • Conveniently utilize the VGA and HDMI ports, and experience integrated sound with the built in dual 1-watt speakers.
  • Create a clean workspace with direct attach capabilities and mounting options enabled by the 100-mm VESA pattern.
  • Experience a FHD 1920 x 1080 resolution image with a 5ms response rate.
Product codes
This work and multimedia monitor won't burden your budget. The HP V214a features a stylish, narrow profile design, compact size and an incredibly low price. Its dynamic contrast of 5,000,000:1 and a typical 5ms response means it maintains sharpness even in faster scenes of movies and games. Due to the anti-reflective surface, the experience won't be spoiled with glares, which you will appreciate on sunny days.
HP V214a - LED monitor - Full HD (1080p) - 20.7"
LED-backlit LCD monitor - 20.7"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2385 mm
Brightness
200 cd/m²
Contrast Ratio
600:1 / 5000000:1 (dynamic)
Response Time
5 ms (On/Off)
Colour Support
16.7 million colours
Input Connectors
HDMI, VGA
Display Position Adjustments
Tilt
Screen Coating
Anti-glare
48.94 cm x 19.7 cm x 36.27 cm
3 kg
English / United Kingdom
Environmental Standards
ENERGY STAR Qualified
Plug and Play, CSA, UL, TUV GS, WHQL, CB, FCC, ISO 9241-307, WEEE, ICES, TUV LBL
1 year warranty
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
HP V214a 1920 x108 LED...
£94.32
