HP V214a 20.7" 1920x1080 5ms HDMI VGA LED Monitor
£88.96
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Conveniently utilize the VGA and HDMI ports, and experience integrated sound with the built in dual 1-watt speakers.
  • Create a clean workspace with direct attach capabilities and mounting options enabled by the 100-mm VESA pattern.
  • Experience a FHD 1920 x 1080 resolution image with a 5ms response rate.
Product codes
Bundle deals (1)
TPLINK 25W 5-PORT USB CHARGER
HP V214a 20.7
£88.96
= £101.96
Save £3.00
  • Crisp presentation features
    Experience a vibrant Full HD 1920 x 1080 resolution image on an ample 52.57 cm (20.7") diagonal screen with a quick 5ms response rate.
  • Efficient, adaptable workspace
    Create a clean, efficient workspace by directly attaching select HP PCs to the back of the monitor- perfect for small spaces, or use the VESA pattern to mount the display on a wall or to an arm or stand.
  • Easy connectivity and audio
    Conveniently utilize the VGA and HDMI ports for centralized connectivity, and experience integrated sound with the built in dual 1-watt speakers for your projects' audio needs.
Enjoy impressive Full HD presentation features with integrated audio on the V214a 52.57 cm (20.7 inch) Monitor. The convenient connectivity, adaptability, and affordable price point are ideal for office use.
HP V214a - LED monitor - Full HD (1080p) - 20.7"
LED-backlit LCD monitor - 20.7"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2385 mm
Brightness
200 cd/m²
Contrast Ratio
600:1 / 5000000:1 (dynamic)
Response Time
5 ms (On/Off)
Colour Support
16.7 million colours
Input Connectors
HDMI, VGA
Display Position Adjustments
Tilt
Screen Coating
Anti-glare
48.94 cm x 19.7 cm x 36.27 cm
3 kg
English / United Kingdom
Environmental Standards
ENERGY STAR Qualified
Plug and Play, CSA, UL, TUV GS, WHQL, CB, FCC, ISO 9241-307, WEEE, ICES, TUV LBL
1 year warranty
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
HP V214a 20.7" 1920x10...
£88.96
