HP V214a 20.7" 1920x1080 5ms HDMI VGA LED Monitor
£95.61
18 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Conveniently utilize the VGA and HDMI ports, and experience integrated sound with the built in dual 1-watt speakers.
  • Create a clean workspace with direct attach capabilities and mounting options enabled by the 100-mm VESA pattern.
  • Experience a FHD 1920 x 1080 resolution image with a 5ms response rate.
  • Diagonal Size: 20.7in
  • Max Resolution: 1920 x 1080
  • Response Time: 5ms
  • Speakers: Speaker(s)
  • Interfaces: DVI, HDMI, VGA (HD-15)
Product codes
Bundle deals (1)
ANTIBACTERIAL WIPES
ANTIBACTERIAL WIPES
= £99.10
Save £1.50
Enjoy impressive Full HD presentation features with integrated audio on the V214a 52.57 cm (20.7 inch) Monitor. The convenient connectivity, adaptability, and affordable price point are ideal for office use.
Product Description HP V214a - LED monitor - Full HD (1080p) - 20.7"
Device Type LED-backlit LCD monitor - 20.7"
Energy Class Class A
Energy Consumption per Year 28 kWh
Power Consumption (On mode) 19 W
Panel Type TN
Aspect Ratio 16:9
Native Resolution Full HD (1080p) 1920 x 1080 at 60 Hz
Pixel Pitch 0.2385 mm
Brightness 200 cd/m²
Contrast Ratio 600:1 / 5000000:1 (dynamic)
Response Time 5 ms (On/Off)
Colour Support 16.7 million colours
Input Connectors HDMI, VGA
Display Position Adjustments Tilt
Screen Coating Anti-glare
Colour Black
Dimensions (WxDxH) 48.94 cm x 19.7 cm x 36.27 cm
Weight 3 kg
Localisation English / United Kingdom
Environmental Standards ENERGY STAR Qualified
Compliant Standards Plug and Play, CSA, UL, TUV GS, WHQL, CB, FCC, ISO 9241-307, WEEE, ICES, TUV LBL
Manufacturer Warranty 1-year warranty
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
HP V214a 20.7" 1920x10...
£95.61
