HP V270 27" 1920x1080 5ms VGA DVI HDMI IPS LED Monitor
£120.94
Delivery:
Key features
  • See more with the generous 27-inch diagonal screen and narrow bezels making it easier for you to maximize productivity and create a stylish workspace.
  • Utilize optimal connectivity options through VGA, DVI, and HDMI inputs while freeing up valuable desk space with the integrated 100-mm VESA pattern.
Product codes
Increase productivity and enjoy expansive Full HD views on the HP V270 27-inch Monitor. The narrow bezels, spacious screen and flexible connectivity are optimal for maximum workplace efficiency at an economical price point.
Product Description HP V270 - LED monitor - Full HD (1080p) - 27"
Device Type LED-backlit LCD monitor - 27"
Panel Type IPS
Aspect Ratio 16:9
Native Resolution Full HD (1080p) 1920 x 1080 at 60 Hz
Pixel Pitch 0.3114 mm
Brightness 300 cd/m²
Contrast Ratio 1000:1 / 10000000:1 (dynamic)
Response Time 5 ms (grey-to-grey)
Input Connectors HDMI, DVI-D, VGA
Display Position Adjustments Tilt
Screen Coating Anti-glare
Colour Black
Dimensions (WxDxH) - with stand 62.02 cm x 23.99 cm x 44.26 cm
Weight 5.2 kg
Localisation English / United Kingdom
Environmental Standards ENERGY STAR Qualified
Compliant Standards Plug and Play, VCCI, BSMI, WHQL, CB, CCC, PSB, KCC, WEEE, MEPS, KC, CECP, CEL, CEL Grade 1, ISC, SEPA
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
HP V270 27" 1920x1080...
£120.94
