HP VH22 Monitor 21.5 Inch
£125.76
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Breeze through your day and achieve optimal productivity when you set the height, tilt, swivel, and pivot for the way you work best.
  • Get legacy and current compatibility with VGA, DVI, and DisplayPort connections.
  • View your everyday content on the 55 cm (21.5") diagonal panel with sharp 1920 x 1080 FHD resolution.
  • Diagonal Size: 21.5in
  • Max Resolution: 1920 x 1080
  • Response Time: 5ms
  • Speakers: None
  • Interfaces: DisplayPort, DVI, VGA (HD-15)
Product codes
Invest wisely, boost productivity, and work comfortably with the business-class HP VH22 55 cm (21.5") Display, which has Full HD resolution, four-way adjustable comfort, and connectivity for your legacy and current technology.
Adjustable, personalized comfort features
Breeze through your day and achieve optimal productivity when you set the height, tilt, and swivel for the way you work best. If you want to work vertically, you can even pivot the display head 90 degrees.
Ample screen size enhanced by Full HD resolution
Enjoy striking views of your everyday content on the 55 cm (21.5") diagonal panel with sharp 1920 x 1080 Full HD resolution.
Flexible, simple connectivity
Get the essential ports you need and want with a VGA connector for legacy compatibility and DVI and DisplayPort for your newer technology.
Product Description HP vh22 - LED monitor - Full HD (1080p) - 21.5"
Device Type LED-backlit LCD monitor - 21.5"
Panel Type TN
Aspect Ratio 16:9
Native Resolution Full HD (1080p) 1920 x 1080 at 60 Hz
Pixel Pitch 0.248 mm
Brightness 250 cd/m²
Contrast Ratio 1000:1 / 5000000:1 (dynamic)
Response Time 5 ms (On/Off)
Colour Support 16.7 million colours
Input Connectors DVI-D, VGA, DisplayPort
Display Position Adjustments Height, pivot (rotation), swivel, tilt
Screen Coating Anti-glare
Colour Black
Dimensions (WxDxH) - with stand 50.76 cm x 19.29 cm x 44.64 cm
Weight 4.5 kg
Localisation English / United Kingdom
Environmental Standards TCO Certified Displays 7, ENERGY STAR Qualified
Compliant Standards Plug and Play, TUV S, WHQL, CB, CCC, cTUVus, TUV Bauart, CEL Grade 1, DIN ISO 9241-307, CoC, low halogen
Manufacturer Warranty 1-year warranty
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
£125.76
