HP Workstation Z240 - Intel Core i7-6700 16GB 256GB SSD 1TB HDD
£1,495.84
Delivery:
Key features
  • Enjoy HP reliability in a budget friendly workstation.
  • Step up to professional workstation computing with the perfect entry level system.
  • The HP Z240 is designed to handle the complexities of your business as they grow. You have the level of performance you need at any stage in your work process.
Product codes
HP's entry level workstations just got better. The HP Z240 with two amazingly versatile form factors, packs the performance, features, and reliability of a workstation into the price point of a desktop PC.
Powered to manage your challenges
Powerful processors, graphics, memory, and two optional ultra-fast HP Z Turbo Drives make the HP Z240 a true workstation-class solution. Handle your growing and complex workloads with performance for any stage in your work process.
Small price, big possibilities
The essential features of the HP Z240 Tower easily support your workload with slots and ports to spare. When you're ready for workstation class features, like professional ISV certifications, the HP Z240 Tower is the right first step.
Priced for your budget
HP's most affordable workstation allows you to customize your experience while still balancing your IT budget. HP reliability, thorough testing, and ISV certification means your HP Z240 is designed as a long-term budget friendly solution.
Choose the OS for you
Support your unique user needs with a choice of Windows 10 Pro or Linux® operating systems.
Better Package. Bigger Punch
Get more performance, expandability and flexibility in the chassis the world loves.
Powerful performance
Achieve the performance you need with your choice of next generation Intel® Xeon® processors or Intel® Core™ processors.
Ultra-fast storage
Handle large files, reduce work time and increase performance with the optional HP Z Turbo Drive.
Work smarter
Up to 64 GB DDR4 ECC memory helps provide no compromise capacity, performance, and reliability.
Geared up graphics
Ignite productivity with NVIDIA® professional graphics cards in 2D or 3D.
See the difference
Access AMD professional graphics including high-end 3D on Tower configurations.
Clean and cool
Help internal components stay clean and cool with a removable and cleanable dust filter.
Product Description HP Workstation Z240 - MT - Core i7 6700 3.4 GHz - 16 GB - SSD 256 GB, HDD 1 TB - UK
Type Workstation - mini tower
Localisation Language: English / region: United Kingdom
Processor 1 x Intel Core i7 (6th Gen) 6700 / 3.4 GHz (4 GHz) (Quad-Core)
Processor Socket LGA1151 Socket
Processor Main Features Hyper-Threading Technology, Intel Turbo Boost Technology 2, Intel Smart Cache
Cache Memory 8 MB
Cache Per Processor 8 MB
RAM 16 GB (installed) / 64 GB (max) - DDR4 SDRAM - non-ECC - PC4-17000
Storage Controller SATA (SATA 6Gb/s)
Hard Drive SSD 256 GB - PCI Express 3.0 x4 - PCI Express - HP Turbo Drive G2
Hard Drive (2nd) HDD 1 TB - SATA 6Gb/s - 7200 rpm
Optical Storage DVD SuperMulti
Card Reader Yes
Graphics Controller PCIe 3.0 x16 - NVIDIA Quadro M2000
Video Memory 4 GB GDDR5 SDRAM
Networking GigE
Keyboard UK
Power AC 120/230 V (50/60 Hz)
OS Provided Microsoft Windows 7 Professional 64-bit Edition (downgrade from Windows 10 Pro 64-bit) + Windows 10 Pro 64-bit Licence
Colour Black
Dimensions (WxDxH) 17 cm x 44.2 cm x 39.9 cm
Weight 8.6 kg
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
HP Workstation Z240 -...
£1,495.84
