Take your business to the next level of performance, expandability, and no compromise reliability in one complete package. The HP Z440 features a perfect mix of HP Z DNA in a performance workstation with powerful processor, spacious RAM, and multiple storage and PCIe configuration options. Here's to more power to you with the HP Z440 Workstation.
Get the job done fast
Cross items off your to-do list fast. Achieve massive computational performance with a single processor personal workstation delivering support for up to 8 cores of processing power. Add in powerful graphics and performance features like optional Thunderbolt™ 21, HP Z Turbo Drive, and HP Remote Graphics Software, and you get a world-class workstation experience that never slows you down.
Customize it to grow with you
When your job requires more, the HP Z440 Workstation, with its sleek 4U form factor, tool-less design, and built in handles make it simple to expand. Easily configure memory, storage, graphics, and more to suit your needs.
Position for the future
Protect your investment and make downtime a thing of the past. Get no-compromise reliability and a standard 3/3/3 limited warranty from the HP Z440 Workstation.
Primed to perform
Achieve the performance you need with next generation Intel® Xeon® processors for up to 8 processor cores in one system.
Graphics pro
Get serious about graphics and reach peak productivity with access to a breadth of AMD professional graphics from entry to high-end 3D.
See everything clearly
Take productivity up a notch with the ability to do more thanks to NVIDIA® professional graphics cards in 2D or 3D.
High-power ports
Maximize your time and increase your capabilities with USB and SATA ports, plus lightning-fast data transfers using optional Thunderbolt™ 2 technology.
A chassis that meets any challenge
A brand new tool-free chassis boasts low acoustics, single integrated Gb Ethernet and more.
Set a new performance curve for your HP Z440
Reduce boot up, calculation, and graphics response and revolutionize how your HP Z440 handles large files with the HP Z Turbo Drive, a remarkably fast and innovative storage solution.
More power to you
You’ll never run out of juice with the 700W Power Supply with two power cables for high-power professional graphics.
See every angle
Take multitasking to a new level with support for up to eight displays.
Your personal system engineer
Optimize this HP Z440 for peak performance. HP Performance Advisor configures your system with updated settings and drivers to help maximize performance.
Product Description | HP Workstation Z440 - MT - Xeon E5-1603V4 2.8 GHz - 8 GB - 1 TB | Type | Workstation - mini tower | Platform Technology | Intel vPro Technology | Height (Rack Units) | 4U | Localisation | Language: English / region: United Kingdom | Processor | 1 x Intel Xeon E5-1603V4 / 2.8 GHz (Quad-Core) | Processor Socket | LGA2011-v3 Socket | Cache Memory | 10 MB | Cache Per Processor | 10 MB | RAM | 8 GB (installed) / 128 GB (max) - DDR4 SDRAM - ECC - PC4-17000 | Storage Controller | SATA (SATA 6Gb/s) | Hard Drive | 1 x 1 TB - SATA 6Gb/s - 7200 rpm | Optical Storage | DVD SuperMulti | Card Reader | 15 in 1 | Graphics Controller | No graphics | Networking | GigE | Power | AC 120/230 V (50/60 Hz) | OS Provided | Windows 10 Home Single Language 64-bit Edition | Colour | Jack black | Dimensions (WxDxH) | 16.891 cm x 44.47 cm x 43.18 cm | Weight | 11 kg | Manufacturer Warranty | Limited warranty - parts and labour - 3 years - on-site |
General | |
Type | Workstation |
Product Form Factor | Mini tower - 4U |
Built-in Devices | Speaker |
Embedded Security | Trusted Platform Module (TPM 1.2) Security Chip |
Processor / Chipset | |
CPU | Intel Xeon E5-1603V4 / 2.8 GHz |
Number of Cores | Quad-Core |
CPU Qty | 1 |
Max CPU Qty | 1 |
CPU Upgradability | Upgradable |
CPU Socket | LGA2011-v3 Socket |
Chipset Type | Intel C612 |
Cache Memory | |
Installed Size | 10 MB |
RAM | |
Installed Size | 8 GB / 128 GB (max) |
Technology | DDR4 SDRAM - ECC |
Effective Memory Speed | 2133 MHz |
Rated Memory Speed | 2133 MHz |
Memory Specification Compliance | PC4-17000 |
Form Factor | DIMM 288-pin |
Slots | 8 (Total) / 6 (empty) |
Features | Registered, quad channel memory architecture |
Configuration Features | 2 x 4 GB |
Hard Drive | |
Type | HDD |
Capacity | 1 x 1 TB |
Interface Type | SATA 6Gb/s |
Spindle Speed | 7200 rpm |
Storage Controller | |
Type | 1 x SATA |
Controller Interface Type | SATA 6Gb/s |
Channel Qty | 6 |
RAID Level | RAID 0, RAID 1, RAID 10 |
Optical Storage | |
Type | DVD SuperMulti - SATA |
Card Reader | |
Type | 15 in 1 card reader |
Monitor | |
Monitor Type | None. |
Graphics Controller | |
Graphics Processor | No graphics |
Audio Output | |
Compliant Standards | High Definition Audio |
Input Device | |
Type | Mouse |
Mouse | |
Technology | Laser |
Interface | USB |
Networking | |
Interface (Bus) Type | PCI Express 1.1 x1 |
Ethernet Controller | Intel I218-LM |
Data Link Protocol | Ethernet, Fast Ethernet, Gigabit Ethernet |
Features | Wake on LAN (WoL), PXE support, auto-uplink (auto MDI/MDI-X) |
Compliant Standards | IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.3z, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.1as, IEEE 802.3az |
Expansion / Connectivity | |
Bays | 1 (total) / 0 (free) x external 5.25" Slim Line , 2 (total) / 2 (free) x external 5.25" , 2 (total) / 1 (free) x internal 3.5" |
Slots | 8 (total) / 6 (free) x DIMM 288-pin , 1 (total) / 0 (free) x CPU , 1 (total) / 1 (free) x PCIe 2.0 x1 - half-length, full-height , 2 (total) / 2 (free) x PCIe 3.0 x16 - full-length, full-height , 1 (total) / 0 (free) x PCIe 2.0 x4 - full-length, full-height , 1 (total) / 1 (free) x PCIe 3.0 x8 - full-length, full-height , 1 (total) / 1 (free) x PCI - full-length, full-height |
Interfaces | 8 x USB 3.0 (4 front, 4 rear) , 1 x headphones/microphone (1 in front) , 1 x microphone (1 in front) , 1 x audio line-in , 1 x audio line-out , 2 x USB 2.0 , 1 x PS/2 keyboard , 1 x PS/2 mouse , 1 x LAN (Gigabit Ethernet) - RJ-45 |
Miscellaneous | |
Included Accessories | HP Processor Air Cooling Kit |
Theft/Intrusion Protection | Security lock slot (cable lock sold separately) |
Security Slot Type | Kensington security slot |
Compliant Standards | RoHS, WEEE, ACPI 4.0 |
Power | |
Device Type | Power supply |
Nominal Voltage | AC 120/230 V (50/60 Hz) |
Power Provided | 700 Watt |
80 PLUS Certification | 80 PLUS |
Efficiency | 90% |
Power Factor Correction | Yes (active) |
Operating System / Software | |
OS Provided | Windows 10 Home Single Language 64-bit Edition English |
Software | Cyberlink PowerDVD, CyberLink Power2Go, HP Performance Advisor, Foxit PhantomPDF Express, HP Remote Graphics Software 7.1 |
Manufacturer Warranty | |
Service & Support | Limited warranty - parts and labour - 3 years - on-site |
Dimensions & Weight | |
Width | 16.891 cm |
Depth | 44.47 cm |
Height | 43.18 cm |
Weight | 11 kg |
Environmental Parameters | |
Min Operating Temperature | 5 °C |
Max Operating Temperature | 35 °C |
Humidity Range Operating | 8 - 85% (non-condensing) |
