HP Workstation Z640 Xeon E5-02630V4 16GB 256GB SSD Windows 10...
HP Workstation Z640 Xeon E5-02630V4 16GB 256GB SSD Windows 10 Pro
£2,876.84
Delivery:
Key features
  • Build your perfect workstation. The HP Z640 Workstation lets you configure and reconfigure with ease.
  • Concentrate on your work not on your system. When every inch, watt, and decibel matters count on the HP Z640 Workstation.
  • Maximize your power while protecting your pocketbook with the high performance, dual socket HP Z640 Workstation.
Product codes
Redefine versatility and flexibility. Expand your capabilities with HP's Z640 Workstation offering powerful performance, whisper-quiet computing, and tool-less access in compact design.
Power up
Experience massive workstation power with support for 145W processors powering up to 36 cores in a dual Intel Xeon processor configuration. The HP Z640 Workstation uses Z DNA to provide a high-end workstation experience.
Versatility redefined
Build the perfect workstation for your needs. The HP Z640 Workstation featuring Windows 8.1 provides incredible expansion in a small footprint. With up to 8 memory DIMMs, up to 4 internal hard drives, optional Thunderbolt 2, and the HP Z Turbo Drive, you get storage, performance, and the freedom to create.
Experience the quiet
Concentrate on your work using a workstation that is whisper quiet. When every inch, watt, and decibel makes a difference, count on the HP Z640 Workstation.
Product Description HP Workstation Z640 - MT - Xeon E5-2630V4 2.2 GHz - 16 GB - 256 GB
Type Workstation - mini tower
Platform Technology Intel vPro Technology
Height (Rack Units) 4U
Localisation Language: English / region: United Kingdom
Processor 1 x Intel Xeon E5-2630V4 / 2.2 GHz (3.1 GHz) (10-core)
Processor Socket LGA2011-v3 Socket
Processor Main Features Hyper-Threading Technology, Intel Turbo Boost Technology 2
Cache Memory 25 MB
Cache Per Processor 25 MB
RAM 16 GB (installed) / 128 GB (max) - DDR4 SDRAM - ECC - PC4-17000
Storage Controller SATA (SATA 6Gb/s)
Hard Drive 1 x SSD 256 GB - PCI Express 2.0 x4 - PCI Express - HP Z Turbo Drive
Optical Storage DVD SuperMulti
Graphics Controller No graphics
Networking GigE
Power AC 120/230 V (50/60 Hz)
OS Provided Microsoft Windows 7 Professional 64-bit Edition (downgrade from Windows 10 Pro 64-bit) + Windows 10 Pro 64-bit Licence
Colour HP black, hematite brushed aluminium
Dimensions (WxDxH) 17.145 cm x 46.48 cm x 44.29 cm
Weight 15 kg
Pricing Type Promo
Manufacturer Warranty Limited warranty - parts and labour - 3 years - on-site
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
HP Workstation Z640 Xe...
£2,876.84
