We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
The HP X27i 2K gaming monitor is key for your everyday gaming demands. Revel in action-packed moments with smooth, crisp visuals supported by a 144Hz refresh rate and AMD FreeSync technology. 2K resolution with IPS panel technology captivates with stunning details.
Product Description | HP X27i Gaming Monitor - LED monitor - 27" | Device Type | LED-backlit LCD monitor - 27" | Energy Class | Class G | Energy Consumption per Year | 41 kWh | Power Consumption (On mode) | 32.1 W | Adaptive-Sync Technology | AMD FreeSync | Panel Type | IPS | Aspect Ratio | 16:9 | Native Resolution | QHD 2560 x 1440 at 144 Hz | Pixel Pitch | 0.233 mm | Brightness | 350 cd/m² | Contrast Ratio | 1000:1 | Response Time | 4 ms (grey-to-grey) | Gaming | Yes | Input Connectors | HDMI, DisplayPort | Display Position Adjustments | Height, pivot (rotation), swivel, tilt | Screen Coating | Anti-glare | Voltage | AC 100 - 240 V | Dimensions (WxDxH) - with stand | 61.12 cm 51.12 cm | Weight | 7.35 kg | Localisation | English / United Kingdom | Compliant Standards | Plug and Play, NOM, TUV S, CB, PSB, ISO 9241-307, WEEE, ICES, TUV Bauart, KC, BIS, DisplayPort 1.2, TUV LBL, Mexico Energy label, Australian-New Zealand MEPS, Vietnam MEPS, South Africa Energy Label | Manufacturer Warranty | 1-year warranty |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 27" |
Panel Type | IPS |
Vertical Refresh Rate | 144 Hz |
Horizontal Refresh Rate | 223 kHz |
Gaming | Yes |
Horizontal Viewing Angle | 178 |
Vertical Viewing Angle | 178 |
Backlight Technology | LED backlight |
Features | HDCP, DreamColor, Flicker Free technology, Technicolour Colour certified, Low Blue Light technology |
Dimensions (WxDxH) | 61.12 cm 51.12 cm - with stand |
Weight | 7.35 kg |
Audio | |
Type | Speakers |
Connectivity | |
Interfaces | DisplayPort , HDMI , Audio line-out , Headphone/microphone combo jack |
Mechanical | |
Tilt Angle | -4/+20 |
Swivel Angle | 360 |
Rotation Angle | 180 |
Height Adjustment | 13.14 cm |
VESA Mounting Interface | 100 mm |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately), arsenic free, mercury free |
Included Accessories | VESA bracket |
Security Slot Type | Kensington security slot |
Power | |
Input Voltage | AC 100 - 240 V |
Power Consumption SDR (On mode) | 32.1 kWh/1000h |
Power Consumption Stand by | 0.32 Watt |
Power Consumption (Off Mode) | 0.24 Watt |
Dimensions & Weight | |
Dimensions & Weight Details | With stand - width: 61.12 cm - height: 51.12 cm - weight: 7.35 kg , Without stand - width: 61.12 cm - depth: 5.81 cm - height: 37.96 cm |
Dimensions & Weight (Shipping) | |
Shipping Width | 70.2 cm |
Shipping Depth | 19 cm |
Shipping Height | 46.3 cm |
Shipping Weight | 9.3 kg |
Manufacturer Warranty | |
Service & Support | Limited warranty - parts and labour - 1 year |
Environmental Parameters | |
Min Operating Temperature | 5 °C |
Max Operating Temperature | 35 °C |
Humidity Range Operating | 20 - 80% (non-condensing) |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
