HP X4000b Bluetooth Mouse
£32.26
Delivery:
Key features
  • The compact, cordless design fits easily into a carrying case alongside your notebook, tablet or Ultrabook™.
  • The high-precision 1600 dpi laser sensor works on most surfaces so you can stay productive wherever the day takes you. The rubber-edge grips make the mouse comfortable and easy to handle in either hand.
  • The mouse works seamlessly with Bluetooth-enabled laptops, Ultrabook™ PCs, and tablets without taking up a valuable USB port. A helpful LED indicator light verifies your connection and alerts you when the battery runs low.
Product codes
Be more productive on the go with the sleek, stylish HP X4000b Bluetooth Mouse that's comfortable wherever you work best and complements your HP Business Notebook, Ultrabook or tablet PC.
Product Description HP X4000B - mouse - Bluetooth
Device Type Mouse
Connectivity Technology Wireless - Bluetooth
Dimensions (WxDxH) 6.71 cm x 10.69 cm x 3.86 cm
Weight 122.5 g
Movement Detection Technology Laser
Movement Resolution 1600 dpi
Battery 2 x AA type
OS Required Microsoft Windows 7, Microsoft Windows Vista
Designed For HP 245 G7, 340S G7, 34X G5, 470 G7; Chromebook 14 G6; Chromebook Enterprise x360; Chromebook x360; Elite x2; EliteBook x360; ENVY x2; Mobile Thin Client mt45; ProBook 430 G7, 440 G7, 445r G6, 450 G7, 455r G6, 640 G5, 650 G5; ProBook x360; ZBook 14u G6, 15 G5, 15 G6, 15u G6, 17 G6, Studio x360 G5
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
£32.26
