General |
Product Type |
Notebook |
Operating System |
Windows 10 Pro 64-bit Edition - English |
Processor / Chipset |
CPU |
Intel Core i7 (7th Gen) 7820HQ / 2.9 GHz |
Max Turbo Speed |
3.9 GHz |
Number of Cores |
Quad-Core |
Cache |
L3 - 8 MB |
64-bit Computing |
Yes |
Chipset |
Mobile Intel CM238 Express |
Features |
Hyper-Threading Technology, Intel Turbo Boost Technology 2.0, Intel Smart Cache |
Memory |
RAM |
32 GB (2 x 16 GB) |
Max RAM Supported |
64 GB |
Technology |
DDR4 SDRAM - non-ECC |
Speed |
2400 MHz / PC4-19200 |
Rated Speed |
2400 MHz |
Form Factor |
SO-DIMM 260-pin |
Slots Qty |
4 |
Empty Slots |
2 |
Storage |
Main Storage |
256 GB SSD - (M.2 2280) PCIe - HP Z Turbo Drive |
RAID Level |
RAID 0, RAID 1 |
Display |
Type |
17.3" - IPS |
LCD Backlight Technology |
LED backlight |
Resolution |
3840 x 2160 (Ultra HD 4K) |
Widescreen |
Yes |
Image Brightness |
300 cd/m² |
Features |
Ultra HD 4K ultra wide-viewing angle (UWVA) anti-glare DreamColor, 254 ppi |
Audio & Video |
Multi-GPU Configuration |
1 single GPU card / integrated GPU |
Graphics Processor |
NVIDIA Quadro P4000 / Intel HD Graphics 630 |
Video Memory |
8 GB GDDR5 SDRAM |
Camera |
Yes - 720p |
Video Resolutions |
1280x720 |
Frame Rate |
30 frames per second |
Camera Features |
Low light enhancement |
Sound |
Stereo speakers, two microphones |
Codec |
CX7501 |
Audio Features |
Bang & Olufsen Audio |
Input |
Type |
Keyboard, touchpad, pointing stick |
Keyboard Backlight |
Yes |
Keyboard Layout |
UK |
Features |
Volume control, spill-resistant, touchpad with gesture support |
Communications |
Wireless |
802.11a/b/g/n/ac, Bluetooth 4.2 |
Wireless Controller |
Intel Dual Band Wireless-AC 8265 - PCI Express Mini Card (M.2) |
Network Interface |
Gigabit Ethernet |
Ethernet Controller |
Intel I219-LM |
Features |
Wake-on-LAN (WOL) |
Compliant Standards |
IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.11b, IEEE 802.11a, IEEE 802.3x, IEEE 802.11g, IEEE 802.3ae, Wi-Fi CERTIFIED, IEEE 802.1as, IEEE 802.11n, IEEE 802.3az, IEEE 802.11ac, Bluetooth 4.2 |
Battery |
Technology |
6-cell Lithium Ion |
Capacity |
96 Wh |
AC Adapter |
Input |
AC 120/230 V (50/60 Hz) |
Output |
200 Watt, 19.5 V |
Connections & Expansion |
Interfaces |
VGA , HDMI , 2 x USB-C 3.1 Gen 2/Thunderbolt 3/DisplayPort , Headphone/microphone combo jack , LAN , 3 x USB 3.0 , USB 3.0 (charging) |
Memory Card Reader |
Yes (SD Card, SDHC Card, SDXC Card, SDXC UHS-II Card) |
Software |
Software Included |
Fingerprint Software, Skype, LANDesk Management Suite, HP Remote Graphics Software, HP SoftPaq Download Manager, HP Recovery Manager, HP Support Assistant, Bing Toolbar, HP ePrint, HP Hotkey Support, HP Performance Advisor, Windows Defender, Device Access Manager, HP Velocity, HP Secure Erase, HP Security Manager, HP Manageability, CyberLink Power Media Player, HP Client Catalog, Absolute Persistence, HP Driver Packs, HP BIOS Config Utility, HP Touchpoint Manager, HP 3D DriveGuard, HP Mobile Connect Pro, HP Image Assistant, HP JumpStart, HP Sure Connect, HP Workwise, HP Noise Cancellation, HP System Software Manager, HP LAN-WLAN Protection, HP Client Security Suite Gen3, HP BIOSphere Gen3, Native Miracast |
Miscellaneous |
Colour |
Space Silver |
Case Material |
Aluminum, magnesium alloy |
Security |
Trusted Platform Module (TPM 2.0) Security Chip, smart card reader |
Features |
HP 3D DriveGuard, HP DuraKeys, One-Step Logon, HP BIOS Protection, HP Automatic Drive Lock, HP DriveLock, Power On Authentication, Pre-boot Authentication, HP Sure Start Gen 3 |
Theft/Intrusion Protection |
Security lock slot (cable lock sold separately) |
Security Slot Type |
Kensington security slot |
Included Accessories |
Power adapter |
ACPI, CSA, UL, FCC, RoHS, WEEE, Common Criteria EAL4+, low halogen |
Localization |
Language: English / region: United Kingdom |
Dimensions & Weight |
Dimensions (WxDxH) |
42 cm x 28 cm x 3.3 cm |
Weight |
3.14 kg |
Environmental Standards |
ENERGY STAR Certified |
Yes |
Manufacturer Warranty |
Service & Support |
Limited warranty - parts and labour - 3 years |
Environmental Parameters |
Min Operating Temperature |
0 °C |
Max Operating Temperature |
35 °C |
Humidity Range Operating |
10 - 90% (non-condensing) |
Shock Tolerance (operating) |
40 g @ 2 ms half-sine pulse |
Shock Tolerance (non-operating) |
200 g @ 2 ms half-sine pulse |
Vibration Tolerance (operating) |
0.75 g @ RMS (random) |
Vibration Tolerance (non-operating) |
1.5 g @ RMS (random) |
