HP Z Display Z23n G2 23" 1920 x 1080 7MS LED Full HD Mon...
HP Z Display Z23n G2 23" 1920 x 1080 7MS LED Full HD Monitor
£195.21
Delivery:
Standard: 1-3 working days
Key features
  • Consistent, accurate color between displays and from project to project is easier than ever with factory color calibration from the very first time you power on.
  • Make the most of your available workspace by mounting powerful machines like the HP Z2 Mini Workstation directly behind the display for a compact, efficient, single-footprint solution.
  • Multi-task on a multi-display array with a 3-sided micro-edge design, and get stunning visuals with a high resolution, 58.42 cm (23”) diagonal IPS screen and over 2 million pixels.
  • We rigorously test every HP Z Display to help ensure its reliability and long life, and the stringent HP Zero Bright Dot Guarantee replaces the screen if even one bright sub-pixel fails.
  • Diagonal Size: 23in
  • Max Resolution: 1920 x 1080
  • Response Time: 5ms
  • Speakers: None
  • Interfaces: DisplayPort, HDMI, VGA (HD-15)
Product codes
Bundle deals (1)
ANTIBACTERIAL WIPES
ANTIBACTERIAL WIPES
= £198.70
Save £1.50
Be a productive powerhouse with the sleek HP Z23n G2 58.42 cm (23") Display. This virtually seamless Full HD display is factory-tested for reliability and longevity with integrated color calibration, uninterrupted multi-screen tiling, and expansive device connections.
Product Description HP Z23n G2 - LED monitor - Full HD (1080p) - 23"
Device Type LED-backlit LCD monitor - 23"
Energy Class Class A
Energy Consumption per Year 31 kWh
Power Consumption (On mode) 21 W
Features USB 3.0 hub
Panel Type IPS
Aspect Ratio 16:9
Native Resolution Full HD (1080p) 1920 x 1080 at 75 Hz
Pixel Pitch 0.2652 mm
Brightness 250 cd/m²
Contrast Ratio 1000:1 / 10000000:1 (dynamic)
Response Time 5 ms (grey-to-grey)
Colour Support 16.7 million colours
Input Connectors HDMI, VGA, DisplayPort
Display Position Adjustments Height, pivot (rotation), swivel, tilt
Screen Coating Anti-glare
Colour Black Pearl
Dimensions (WxDxH) - without stand 52.1 cm x 4.33 cm x 31.17 cm
Weight 3.3 kg
Localisation English / United Kingdom
Environmental Standards TCO Certified Displays 7, TCO Certified Edge Displays, ENERGY STAR Qualified
Compliant Standards Plug and Play, VCCI, BSMI, GS, TUV S, WHQL, CB, CCC, PSB, FCC, ISO 9241-307, WEEE, ICES, cTUVus, MEPS, E-Standby, KC, ERP, CEL, CEL Grade 1, ISC, RCM, MSIP, SEPA, CoC, low halogen, CU, SmartWay
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
HP Z Display Z23n G2 2...
£195.21
