HP Z Display Z23n G2 23" 1920 x 1080 7MS LED Full HD Mon...
HP Z Display Z23n G2 23" 1920 x 1080 7MS LED Full HD Monitor
£195.21
17 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Consistent, accurate color between displays and from project to project is easier than ever with factory color calibration from the very first time you power on.
  • Make the most of your available workspace by mounting powerful machines like the HP Z2 Mini Workstation directly behind the display for a compact, efficient, single-footprint solution.
  • Multi-task on a multi-display array with a 3-sided micro-edge design, and get stunning visuals with a high resolution, 58.42 cm (23”) diagonal IPS screen and over 2 million pixels.
  • We rigorously test every HP Z Display to help ensure its reliability and long life, and the stringent HP Zero Bright Dot Guarantee replaces the screen if even one bright sub-pixel fails.
  • Diagonal Size: 23in
  • Max Resolution: 1920 x 1080
  • Response Time: 5ms
  • Speakers: None
  • Interfaces: DisplayPort, HDMI, VGA (HD-15)
Product codes
Bundle deals (1)
ANTIBACTERIAL WIPES
ANTIBACTERIAL WIPES
= £198.70
Save £1.50
Be a productive powerhouse with the sleek HP Z23n G2 58.42 cm (23") Display. This virtually seamless Full HD display is factory-tested for reliability and longevity with integrated color calibration, uninterrupted multi-screen tiling, and expansive device connections.
Product Description HP Z23n G2 - LED monitor - Full HD (1080p) - 23"
Device Type LED-backlit LCD monitor - 23"
Energy Class Class A
Energy Consumption per Year 31 kWh
Power Consumption (On mode) 21 W
Features USB 3.0 hub
Panel Type IPS
Aspect Ratio 16:9
Native Resolution Full HD (1080p) 1920 x 1080 at 75 Hz
Pixel Pitch 0.2652 mm
Brightness 250 cd/m²
Contrast Ratio 1000:1 / 10000000:1 (dynamic)
Response Time 5 ms (grey-to-grey)
Colour Support 16.7 million colours
Input Connectors HDMI, VGA, DisplayPort
Display Position Adjustments Height, pivot (rotation), swivel, tilt
Screen Coating Anti-glare
Colour Black Pearl
Dimensions (WxDxH) - without stand 52.1 cm x 4.33 cm x 31.17 cm
Weight 3.3 kg
Localisation English / United Kingdom
Environmental Standards ENERGY STAR Qualified
Compliant Standards Plug and Play, VCCI, BSMI, GS, TUV S, WHQL, CB, CCC, PSB, FCC, ISO 9241-307, WEEE, ICES, cTUVus, MEPS, E-Standby, KC, ERP, CEL, CEL Grade 1, ISC, RCM, MSIP, SEPA, CoC, low halogen, CU, SmartWay
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
HP Z Display Z23n G2 2...
£195.21
