This mini PC delivers amazing power and versatility in a small, elegant design. Made by and for design professionals, the Z2 Mini gives you both performance and reliability.
Next-level power
Get server-grade power in a remarkably small device. Intel® Xeon® processors and NVIDIA® Quadro® graphics keep up with the speed of your creativity.
Designed for the workspace of the future
We packed workstation performance into a mini PC with a design that will turn heads. Our most flexible and most beautiful workstation ever—perfect for every office environment.
Industry-leading reliability
Tech issues should never hold you back. The Z2 Mini is tested for 368,000 hours and certified for the most popular CAD software. Feel confident using a workstation influenced by over 30 years of engineering and backed by a 3-year standard limited warranty.
Product Description | HP Workstation Z2 Mini G3 Performance - mini - Xeon E3-1225V5 3.3 GHz - 16 GB - 256 GB - UK | Type | Workstation - mini | Platform Technology | Intel vPro Technology | Localisation | Language: English / region: United Kingdom | Processor | 1 x Intel Xeon E3-1225V5 / 3.3 GHz (3.7 GHz) (Quad-Core) | Processor Socket | LGA1151 Socket | Processor Main Features | Intel Turbo Boost Technology 2, Intel Smart Cache | Cache Memory | 8 MB | Cache Per Processor | 8 MB | RAM | 16 GB (installed) / 32 GB (max) - DDR4 SDRAM - ECC | Storage Controller | SATA (SATA 6Gb/s) | Hard Drive | 1 x SSD 256 GB - PCI Express 3.0 x4 - HP Z Turbo Drive G2 | Optical Storage | No optical drive | Graphics Controller | Intel HD Graphics P530 Shared Video Memory (UMA) | Audio Output | Stereo | Networking | GigE | Keyboard | UK | Power | AC 120/230 V (50/60 Hz) | OS Provided | Microsoft Windows 7 Professional 64-bit Edition (downgrade from Windows 10 Pro 64-bit) + Windows 10 Pro 64-bit Licence | Colour | Space grey with black chrome accents | Dimensions (WxDxH) | 21.6 cm x 21.6 cm x 5.8 cm | Weight | 2.04 kg | Pricing Type | Promo | Environmental Standards | ENERGY STAR Qualified | Manufacturer Warranty | Limited warranty - parts and labour - 3 years - on-site |
General | |
Type | Workstation |
Product Form Factor | Mini |
Built-in Devices | Speaker |
Embedded Security | Trusted Platform Module (TPM 2.0) Security Chip |
Processor / Chipset | |
CPU | Intel Xeon E3-1225V5 / 3.3 GHz |
Max Turbo Speed | 3.7 GHz |
Number of Cores | Quad-Core |
CPU Qty | 1 |
Max CPU Qty | 1 |
CPU Upgradability | Upgradable |
CPU Socket | LGA1151 Socket |
Chipset Type | Intel C236 |
Cache Memory | |
Installed Size | 8 MB |
RAM | |
Installed Size | 16 GB / 32 GB (max) |
Technology | DDR4 SDRAM - ECC |
Effective Memory Speed | 2400 MHz |
Rated Memory Speed | 2400 MHz |
Form Factor | SO-DIMM 260-pin |
Slots | 2 (Total) / 0 (empty) |
Features | Unbuffered |
Configuration Features | 2 x 8 GB |
RAM Supported | 32 GB unbuffered - ECC , 32 GB unbuffered - non-ECC |
Hard Drive | |
Type | SSD |
Capacity | 1 x 256 GB |
Interface Type | PCI Express 3.0 x4 |
Features | HP Z Turbo Drive G2 multi-level cell (MLC) |
Storage Controller | |
Type | 1 x SATA |
Controller Interface Type | SATA 6Gb/s |
Optical Storage | |
Type | No optical drive |
Monitor | |
Monitor Type | None. |
Graphics Controller | |
Graphics Processor | Intel HD Graphics P530 Shared Video Memory (UMA) |
Video Interfaces | DVI, DisplayPort |
Max Monitors Supported | 3 |
Audio Output | |
Sound Output Mode | Stereo |
Compliant Standards | High Definition Audio |
Input Device | |
Type | Mouse, keyboard |
Keyboard | |
Keyboard Name | HP USB Business Slim Keyboard |
Interface | USB |
Localization & Layout | UK |
Mouse | |
Technology | Laser |
Interface | USB |
Networking | |
Ethernet Controller | Intel I219-LM |
Data Link Protocol | Ethernet, Fast Ethernet, Gigabit Ethernet |
Remote Management Protocol | ASF 2.0 |
Features | Wake on LAN (WoL), PXE support |
Compliant Standards | IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.3z, IEEE 802.1Q, IEEE 802.1p, IEEE 802.1as, IEEE 802.3az |
Expansion / Connectivity | |
Bays | 1 (total) / 1 (free) x internal 2.5" |
Slots | 2 (total) / 0 (free) x SO-DIMM 260-pin , 1 (total) / 0 (free) x CPU , 1 (total) / 1 (free) x M.2 Card - 2280 (x4 mode) , 2 (total) / 1 (free) x PCIe 3.0 |
Interfaces | 4 x USB 3.0 (2 front, 2 rear) (one of them is charging) , 1 x headphones/microphone (1 in front) , 1 x LAN (Gigabit Ethernet) - RJ-45 , 2 x USB-C 3.1 Gen 1 (2 rear) , 1 x DVI , 1 x DisplayPort |
Miscellaneous | |
Theft/Intrusion Protection | Security lock slot (cable lock sold separately) |
Security Slot Type | Kensington security slot |
Compliant Standards | ACPI, RoHS, WEEE, low halogen |
Power | |
Device Type | Power adapter |
Nominal Voltage | AC 120/230 V (50/60 Hz) |
Power Provided | 200 Watt |
Efficiency | 89% |
Power Factor Correction | Yes (active) |
Operating System / Software | |
OS Provided | Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 10 Pro 64-bit) + Windows 10 Pro 64-bit Licence - English |
Software | HP Performance Advisor, HP PC Hardware Diagnostics UEFI, HP Client Security, HP Remote Graphics Software 7.1 |
Environmental Standards | |
ENERGY STAR Certified | Yes |
Manufacturer Warranty | |
Service & Support | Limited warranty - parts and labour - 3 years - on-site |
Dimensions & Weight | |
Width | 21.6 cm |
Depth | 21.6 cm |
Height | 5.8 cm |
Weight | 2.04 kg |
Environmental Parameters | |
Min Operating Temperature | 5 °C |
Max Operating Temperature | 35 °C |
Humidity Range Operating | 8 - 85% |
