HP Z2 G4 Core i7-8700 8GB 1TB Windows 10 Pro
£757.83
26 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Get powerful protection from evolving malware threats with HP's security suite and easily manage your devices with the HP Manageability Integration Kit Gen2 .
  • HP's most expandable entry workstation is designed to grow with you. Whether you need to swap graphics, increase CPU power or add PCIe cards, the Z2 Tower can meet evolving needs.
  • The Z2 Tower is equipped to handle demanding 3D projects with high-end certified professional graphics power. Get full, unthrottled performance even with your heaviest workloads.
Product codes
Experience server-grade power in a desktop workstation with impressive expandability. Confidently tackle complex workloads like BIM and rendering with up to Ultra 3D graphics and the latest Intel Core or Intel Xeon processors.
Product Description HP Workstation Z2 G4 - MT - Core i7 8700 3.2 GHz - 8 GB - 1 TB - UK layout
Type Workstation - mini tower
Platform Technology Intel vPro Technology
Localisation Language: English / region: United Kingdom
Processor 1 x Intel Core i7 (8th Gen) 8700 / 3.2 GHz (4.6 GHz) (6-core)
Processor Main Features Hyper-Threading Technology, Intel Turbo Boost Technology 2, Intel Smart Cache
Cache Memory 12 MB
Cache Per Processor 12 MB
RAM 8 GB (installed) / 64 GB (max) - DDR4 SDRAM - non-ECC - PC4-21333
Storage Controller SATA (SATA 6Gb/s)
Hard Drive 1 x 1 TB - SATA 6Gb/s - 7200 rpm
Optical Storage DVD-Writer
Graphics Controller Intel UHD Graphics 630 Dynamic Video Memory Technology 5.0
Networking GigE
Power AC 120/230 V (50/60 Hz)
OS Provided Windows 10 Pro 64-bit Edition
Colour Black
Dimensions (WxDxH) 16.9 cm x 43.5 cm x 35.6 cm
Weight 7 kg
Manufacturer Warranty Limited warranty - parts and labour - 3 years - on-site
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
HP Z2 G4 Core i7-8700...
£757.83
