HP Z2 G4 Core i7-8700K 8GB 1TB Windows 10 Pro
£1,214.12
Delivery:
Key features
  • Build a system matched exactly to your needs with over a million possible configurations. Customizable I/O ports support new, legacy and specialized equipment without messy dongles.
  • Crush demanding workflows and take on aggressive multi-tasking without throttling. We redesigned our proprietary motherboard to give you full performance, while keeping components running cool and quiet.
  • System safeguards like HP Client Security Suite Gen3 and HP Sure Start Gen4 - the industry‚Äôs first self-healing BIOS - mean your device is locked down tight, so your data and identity are too.
  • Processor Type: Core i7
  • Operating System: Windows 10 Pro 64-bit Edition
  • Installed Memory: 8GB
  • Hard Drive Capacity: 1TB
  • Storage Type: HDD
Product codes
Get next-level performance with a compact device that can easily handle single and multi-threaded applications. With nearly endless configuration options, the Z2 SFF is the perfect hardware solution for your customization needs.
Product Description HP Workstation Z2 G4 - SFF - Core i7 8700 3.2 GHz - 8 GB - 1 TB - UK
Type Workstation - small form factor
Platform Technology Intel vPro Technology
Localisation Language: English / region: United Kingdom
Processor 1 x Intel Core i7 (8th Gen) 8700 / 3.2 GHz (4.6 GHz) (6-core)
Processor Socket LGA1151 Socket
Processor Main Features Hyper-Threading Technology, Intel Turbo Boost Technology 2, Intel Smart Cache
Cache Memory 12 MB
Cache Per Processor 12 MB
RAM 8 GB (installed) / 64 GB (max) DDR4 SDRAM - non-ECC - PC4-21333
Storage Controller SATA (SATA 6Gb/s)
Hard Drive 1 x 1 TB - SATA 6Gb/s - 7200 rpm
Optical Storage DVD-Writer
Graphics Controller Intel UHD Graphics 630 Dynamic Video Memory Technology 5.0
Networking GigE
Keyboard UK
OS Provided Windows 10 Pro 64-bit Edition
Colour Black
Dimensions (WxDxH) 33.8 cm x 38.1 cm x 10 cm
Weight 5.5 kg
Manufacturer Warranty Limited warranty - parts and labour - 3 years - on-site
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
HP Z2 G4 Core i7-8700K...
£1,214.12
