HP Z2 G4 Intel Xeon E-2104G 16GB 512GB SSD Windows 10 Pro
£1,462.74
Delivery:
Key features
  • Get powerful protection from evolving malware threats with HP's security suite and easily manage your devices with the HP Manageability Integration Kit Gen2.
  • Improve your workspace with the versatile design. Mount under a desk, behind a display or in a rack. Flexible I/O ports for peripheral and connectivity needs create the ideal setup.
  • Whether designing in 3D or running multiple apps, high-speed CPUs and professional GPUs optimize your performance. Plus, leading software certifications mean reliable performance.
Product codes
Get next-level performance with a remarkably small and versatile device that can handle single and multi-threaded software. With the ability to support the latest technology and workforce demands, it's the obvious choice for the modern workplace.
Product Description HP Workstation Z2 Mini G4 Entry - mini - Xeon E-2104G 3.2 GHz - 16 GB - SSD 512 GB - UK
Type Workstation - mini
Localisation Language: English / region: United Kingdom
Processor 1 x Intel Xeon E-2104G / 3.2 GHz (Quad-Core)
Processor Main Features Intel Turbo Boost Technology 2
Cache Memory 8 MB
Cache Per Processor 8 MB
RAM 16 GB (installed) / 32 GB (max) - DDR4 SDRAM - non-ECC - PC4-21333
Storage Controller SATA (SATA 6Gb/s)
Hard Drive SSD 512 GB - PCI Express 3.0 x4 - M.2 2280 - HP Z Turbo Drive G2, NVM Express (NVMe)
Optical Storage No optical drive
Graphics Controller Intel HD Graphics P630 Shared Video Memory (UMA)
Audio Output Stereo
Networking GigE
Keyboard UK
Power AC 120/230 V (50/60 Hz)
OS Provided Windows 10 Pro 64-bit Edition
Colour Space grey with black chrome accents
Dimensions (WxDxH) 21.6 cm x 21.6 cm x 5.8 cm
Weight 1.93 kg
Manufacturer Warranty Limited warranty - parts and labour - 3 years - on-site
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
HP Z2 G4 Intel Xeon E-...
£1,462.74
