HP Z2 G4 MT Intel Xeon W-2102 8GB 1TB HDD Windows 10 Pro
£1,597.21
Delivery:
Key features
  • Advanced security features come standard on every Z4. Rest assured your device, identity and data are safe with security software like HP Client Security Suite Gen3 and HP Sure Start Gen3.
  • Visualize your project anytime by moving seamlessly between 3D CAD, rendering and simulation applications. The Z4 can easily handle tasks that require high frequency processing, multiple cores and high-powered GPUs.
  • With more standard features than any other single processor HP workstation, you can choose the perfect blend of components that meet your performance requirements.
  • Processor Type: Xeon
  • Operating System: Windows 10 Pro 64-bit Edition
  • Installed Memory: 8GB
  • Hard Drive Capacity: 1TB
  • Storage Type: HDD
Product codes
Perfect for engineering, visualization and Machine Learning, HP's most popular workstation delivers disruptive performance for a wide spectrum of applications. With a choice of Intel Xeon or Core X processors, and support for dual extreme graphics, you get all you need, nothing more.
Product Description HP Workstation Z4 G4 - MT - Xeon W-2102 2.9 GHz - 8 GB - 1 TB - UK
Type Workstation - mini tower
Platform Technology Intel vPro Technology
Height (Rack Units) 4U
Localisation Language: English / region: United Kingdom
Processor 1 x Intel Xeon W-2102 / 2.9 GHz (Quad-Core)
Processor Socket LGA2066 Socket
Processor Main Features Hyper-Threading Technology
Cache Memory 8.25 MB
Cache Per Processor 8.25 MB
RAM 8 GB (installed) / 256 GB (max) - DDR4 SDRAM - ECC - PC4-20800
Storage Controller SATA (SATA 6Gb/s)
Hard Drive 1 x 1 TB - SATA 6Gb/s - 7200 rpm
Optical Storage DVD-Writer
Graphics Controller No graphics
Networking GigE
Keyboard UK
Power AC 120/230 V (50/60 Hz)
OS Provided Windows 10 Pro 64-bit Edition
Colour Black
Dimensions (WxDxH) 16.9 cm x 44.5 cm x 38.6 cm
Weight 11.3 kg
Environmental Standards ENERGY STAR Qualified
Manufacturer Warranty Limited warranty - parts and labour - 3 years - on-site
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
HP Z2 G4 MT Intel Xeon...
£1,597.21
