HP Z240 MT Core i7-7700 8GB 256GB SSD Windows 10 Pro
Key features
  • Enjoy HP reliability in a budget friendly workstation.
  • Step up to professional workstation computing with the perfect entry level system.
  • The HP Z240 is designed to handle the complexities of your business as they grow. You have the level of performance you need at any stage in your work process.
Product codes
HP's entry level workstations just got better. The HP Z240 with two amazingly versatile form factors, packs the performance, features, and reliability of a workstation into the price point of a desktop PC.
Product Description HP Workstation Z240 - MT - Core i7 7700 3.6 GHz - 8 GB - 256 GB - UK
Type Workstation - mini tower
Localisation Language: English / region: United Kingdom
Processor 1 x Intel Core i7 (7th Gen) 7700 / 3.6 GHz (4.2 GHz) (Quad-Core)
Processor Socket LGA1151 Socket
Processor Main Features Hyper-Threading Technology, Intel Turbo Boost Technology 2, Intel Smart Cache
Cache Memory 8 MB
Cache Per Processor 8 MB
RAM 8 GB (installed) / 64 GB (max) - DDR4 SDRAM - non-ECC - PC4-17000
Storage Controller SATA (SATA 6Gb/s)
Hard Drive 1 x SSD 256 GB - SATA 6Gb/s
Optical Storage DVD
Card Reader Yes
Graphics Controller Intel HD Graphics 630 Shared Video Memory (UMA)
Networking GigE
Keyboard UK
Power AC 120/230 V (50/60 Hz)
OS Provided Windows 10 Pro 64-bit Edition
Colour Black
Dimensions (WxDxH) 17 cm x 44.2 cm x 39.9 cm
Weight 8.6 kg
Environmental Standards ENERGY STAR Qualified
Manufacturer Warranty Limited warranty - parts and labour - 3 years - on-site
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
HP Z240 MT Core i7-770...
