HP Z24n 24" 1920x1200 8ms DVI DisplayPort IPS LED Monitor
Key features
  • Connect to your everyday devices with integrated HDMI, mDP, DP, MHL, DVI, and a USB 3.0 hub with a fast-charging port. The DisplayPort output allows you to daisy chain up to two displays with just one PC or workstation connection.
  • Count on a factory-calibrated 99% sRGB color gamut from the very first time you power on for reliable, accurate color between displays and from project to project.
  • Enjoy stunning high resolution, maximize your view, and seamlessly tile multiple displays with a design that only has a border on one side.
Product codes
Create a seamless 16:10 multi-display setup with the HP Z24n Narrow Bezel IPS Display, which has a virtually borderless screen for maximum impact imagery, factory color calibration to ensure optimal color accuracy, and flexible connectivity for all of your devices.
HP Z24n - LED monitor - 24"
LED-backlit LCD monitor - 24"
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:10
Native Resolution
1920 x 1200 at 60 Hz
Pixel Pitch
0.27 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1 / 5000000:1 (dynamic)
Response Time
14 ms (grey-to-grey), 8 ms (overdrive)
Colour Support
16.7 million colours
Input Connectors
DVI-D, DisplayPort, Mini DisplayPort, HDMI (MHL)
Display Position Adjustments
Screen Coating
Anti-glare
53.38 cm x 21.01 cm x 52.02 cm
5.78 kg
English / United Kingdom
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
Plug and Play, UL, TUV GS, VCCI, C-Tick, BSMI, TUV S, WHQL, CB, CCC, TUV Ergo, FCC, TCO Certified Edge, KC, CECP, TCO Displays, CEL Grade 1, SEPA
5 years warranty
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
HP Z24n 24" 1920x1200...
