HP Z24n G2 24" 1920x1200 DP HDMI DVI-D USB-C LED monitor
FREE DELIVERY
£257.97
Delivery:
Notify me
Key features
  • Consistent, accurate color between displays and from project to project is easier than ever with factory color calibration from the very first time you power on.
  • Get a clean, single USB-C™ cable video and data connection that’s ready for future generations of HP Workstations, plus multi-generation compatible VGA, HDMI, and DisplayPort™ and three USB 3.0.
  • Streamline multi-display multi-tasking with a 3-sided micro-edge and daisy chain up to 3 displays per workstation with DisplayPort™. Get stunning visuals from high resolution and over 2.3 million pixels.
  • We rigorously test every HP Z Display to help ensure its reliability and long life, and the stringent HP Zero Bright Dot Guarantee replaces the screen if even one bright sub-pixel fails.
  • Diagonal Size: 24in
  • Max Resolution: 1920 x 1200
  • Response Time: 5.8ms
  • Interfaces: DisplayPort, DVI, HDMI, USB-C
Product codes
Be a productive powerhouse with the sleek WUXGA HP Z24n G2 60.96 cm (24") Display. This virtually seamless display is factory-tested for reliability and longevity with integrated color calibration, uninterrupted multi-screen tiling, and expansive device connections, including USB-C .
Product Description HP Z24n G2 - LED monitor - 24"
Device Type LED-backlit LCD monitor - 24"
Energy Class Class D
Energy Consumption per Year 53 kWh
Power Consumption (On mode) 15 W
Daisy Chaining Yes
Features USB 3.0/USB-C hub
Panel Type IPS
Aspect Ratio 16:10
Native Resolution WUXGA 1920 x 1200 at 60 Hz
Pixel Pitch 0.27 mm
Brightness 300 cd/m²
Contrast Ratio 1000:1 / 10000000:1 (dynamic)
Response Time 5.8 ms (grey-to-grey), 14 ms (default)
Colour Support 16.7 million colours
Colour Gamut 99% sRGB
Input Connectors DisplayPort, HDMI, DVI-D, USB-C
Display Position Adjustments Height, pivot (rotation), swivel, tilt
Screen Coating Anti-glare, 3H Hard Coating
Voltage AC 120/230 V (50/60 Hz)
Colour Black Pearl
Dimensions (WxDxH) - with stand 53.2 cm x 21.4 cm x 50.3 cm
Weight 7.2 kg
Localisation English / United Kingdom
Environmental Standards ENERGY STAR Qualified
Compliant Standards Plug and Play, VCCI, BSMI, GS, TUV S, WHQL, CB, CCC, PSB, FCC, ISO 9241-307, WEEE, ICES, cTUVus, MEPS, E-Standby, KC, ERP, CEL Grade 1, ISC, RCM, MSIP, CEL Grade 2, SEPA, CoC, CU
Manufacturer Warranty 5-year warranty
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
£257.97
Notify me
