HP Z24n G2 24" 1920x1200 DP HDMI DVI-D USB-C LED monitor
£232.40
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Consistent, accurate color between displays and from project to project is easier than ever with factory color calibration from the very first time you power on.
  • Get a clean, single USB-C™ cable video and data connection that’s ready for future generations of HP Workstations, plus multi-generation compatible VGA, HDMI, and DisplayPort™ and three USB 3.0.
  • Streamline multi-display multi-tasking with a 3-sided micro-edge and daisy chain up to 3 displays per workstation with DisplayPort™. Get stunning visuals from high resolution and over 2.3 million pixels.
  • We rigorously test every HP Z Display to help ensure its reliability and long life, and the stringent HP Zero Bright Dot Guarantee replaces the screen if even one bright sub-pixel fails.
  • Diagonal Size: 24in
  • Max Resolution: 1920 x 1200
  • Response Time: 5.8ms
  • Interfaces: DisplayPort, DVI, HDMI, USB-C
  • Stock Status: In Stock
Product codes
Be a productive powerhouse with the sleek WUXGA HP Z24n G2 60.96 cm (24") Display. This virtually seamless display is factory-tested for reliability and longevity with integrated color calibration, uninterrupted multi-screen tiling, and expansive device connections, including USB-C .
Product Description HP Z24n G2 - LED monitor - 24"
Device Type LED-backlit LCD monitor - 24"
Energy Class Class B
Energy Consumption per Year 53 kWh
Power Consumption (On mode) 36 W
Features USB 3.0/USB-C hub
Panel Type IPS
Aspect Ratio 16:10
Native Resolution WUXGA 1920 x 1200 at 60 Hz
Pixel Pitch 0.27 mm
Brightness 300 cd/m²
Contrast Ratio 1000:1 / 10000000:1 (dynamic)
Response Time 14 ms (default), 5.8 ms (grey-to-grey)
Colour Support 16.7 million colours
Input Connectors DisplayPort, HDMI, DVI-D, USB-C
Display Position Adjustments Height, pivot (rotation), swivel, tilt
Screen Coating Anti-glare, 3H Hard Coating
Colour Black Pearl
Dimensions (WxDxH) - with stand 53.2 cm x 21.4 cm x 50.3 cm
Weight 7.2 kg
Localisation English / United Kingdom
Environmental Standards TCO Certified Displays 7, TCO Certified Edge Displays, ENERGY STAR Qualified
Compliant Standards Plug and Play, VCCI, BSMI, GS, TUV S, WHQL, CB, CCC, PSB, FCC, ISO 9241-307, WEEE, ICES, cTUVus, MEPS, E-Standby, KC, ERP, CEL Grade 1, ISC, RCM, MSIP, CEL Grade 2, SEPA, CoC, CU
Manufacturer Warranty 5-year warranty
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
HP Z24n G2 24" 1920x12...
£232.40
