Be a productive powerhouse with the sleek HP Z24nf G2 60.45 cm (23.8") Display. This virtually seamless Full HD display is factory-tested for reliability and longevity with integrated color calibration, uninterrupted multi-screen tiling, and expansive device connections.
Product Description | HP Z24nf G2 - LED monitor - Full HD (1080p) - 23.8" | Device Type | LED-backlit LCD monitor - 23.8" | Energy Class | Class A | Energy Consumption per Year | 34 kWh | Power Consumption (On mode) | 23 W | Features | USB 3.0 hub | Panel Type | IPS | Aspect Ratio | 16:9 | Native Resolution | Full HD (1080p) 1920 x 1080 at 60 Hz | Pixel Pitch | 0.274 mm | Brightness | 250 cd/m² | Contrast Ratio | 1000:1 / 10000000:1 (dynamic) | Response Time | 5 ms (grey-to-grey) | Colour Support | 16.7 million colours | Input Connectors | HDMI, VGA, DisplayPort | Display Position Adjustments | Height, pivot (rotation), swivel, tilt | Screen Coating | Anti-glare | Colour | Black Pearl | Dimensions (WxDxH) - with stand | 53.88 cm x 20.5 cm x 46.3 cm | Weight | 5.6 kg | Localisation | English / United Kingdom | Environmental Standards | TCO Certified Displays 7, TCO Certified Edge Displays, ENERGY STAR Qualified | Compliant Standards | Plug and Play, VCCI, BSMI, TUV S, WHQL, CB, CCC, PSB, FCC, ISO 9241-307, WEEE, ICES, cTUVus, MEPS, E-Standby, KC, ERP, CEL, ISC, RCM, MSIP, SEPA, CoC, low halogen, CU, SmartWay | Manufacturer Warranty | 5-year warranty |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 23.8" |
Viewable Size | 23.8" |
Built-in Devices | USB 3.0 hub |
Panel Type | IPS |
Pixel Per Inch | 93 |
Vertical Refresh Rate | 50 - 75 Hz |
Horizontal Refresh Rate | 30 - 84 kHz |
Horizontal Viewing Angle | 178 |
Vertical Viewing Angle | 178 |
Backlight Technology | LED backlight |
OSD Languages | Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Spanish, Dutch, Japanese |
Features | Zero Bright Dot, HDCP, arsenic-free glass, 95% sRGB colour gamut, micro-bezel design |
Dimensions (WxDxH) | 53.88 cm x 20.5 cm x 46.3 cm - with stand |
Weight | 5.6 kg |
Connectivity | |
Interfaces | VGA , HDMI (HDCP) , DisplayPort (HDCP) , USB 3.0 upstream , 2 x USB 3.0 downstream |
Mechanical | |
Tilt Angle | -5/+22 |
Swivel Angle | 90 |
Height Adjustment | 150 mm |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately), detachable stand |
Cables Included | 1 x DisplayPort cable - 2 m , 1 x USB cable - USB Type A to B - 1.8 m |
Backlight Life | 30,000 hours |
Security Slot Type | Kensington security slot |
Power | |
Voltage Required | AC 120/230 V (50/60 Hz) |
Power Consumption Operational | 19 Watt |
Power Consumption Stand by | 0.5 Watt |
On / Off Switch | Yes |
Software / System Requirements | |
Included Software | Display drivers, HP Display Assistant |
Dimensions & Weight | |
Dimensions & Weight Details | Without stand - width: 53.2 cm - depth: 4.38 cm - height: 32.19 cm - weight: 3.1 kg , With stand - width: 53.88 cm - depth: 20.5 cm - height: 46.3 cm - weight: 5.6 kg |
Dimensions & Weight (Shipping) | |
Shipping Width | 62 cm |
Shipping Depth | 40 cm |
Shipping Height | 27.3 cm |
Shipping Weight | 8.3 kg |
Environmental Standards | |
ENERGY STAR Certified | Yes |
TCO Certified | TCO Certified Displays 7, TCO Certified Edge Displays |
Manufacturer Warranty | |
Service & Support | Limited warranty - 5 years - on-site - response time: next business day |
Environmental Parameters | |
Min Operating Temperature | 5 °C |
Max Operating Temperature | 35 °C |
Humidity Range Operating | 20 - 80% (non-condensing) |
