HP Z24u G3 24" 1920x1200 5ms 5ms HDMI DisplayPort USB-C...
FREE DELIVERY
HP Z24u G3 24" 1920x1200 5ms 5ms HDMI DisplayPort USB-C IPS LED Monitor
£409.84
15 In Stock
Delivery:
Standard: 1-3 working days
Key features
  • Get remarkable color accuracy and precise, vibrant detail with 99% sRBG color gamut and WUXGA resolution.
  • Meticulously crafted with a frameless design this 24 inch diagonal screen monitor powers your PC or Mac and lets you work comfortably with 4 way ergonomic adjustability.
  • Experience exceptional vibrancy with HP Eye Ease, the always on low blue light filter that reduces blue light exposure with zero impact to true color accuracy.
  • Its plastics consist of over 80% recycled materials plus it has 100% sustainably sourced and recyclable packaging.
  • Diagonal Size: 24in
  • Max Resolution: 1920 x 1200
  • Response Time: 5ms
  • Speakers: None
  • Interfaces: HDMI, DisplayPort, USB-C
Product codes
Meticulously crafted to surpass every design standard, the HP Z24u G3 WUXGA USB-C Display is composed of authentic aluminum and delivers an impressive, frameless viewing experience. Bring your ideas to life with remarkable color accuracy in precise WUXGA resolution. Refine your work experience and transform your PC into a powerhouse with this 24 inch diagonal screen monitor with USB-C 100W Power Delivery.
Product Description HP Z24u G3 - LED monitor - 24"
Device Type LED-backlit LCD monitor - 24"
Energy Class Class E
Energy Consumption per Year 28 kWh
Power Consumption (On mode) 18.6 W
Daisy Chaining Yes
Features USB 3.2 Gen 1 hub
Panel Type IPS
Aspect Ratio 16:10
Native Resolution WUXGA 1920 x 1200 at 60 Hz
Pixel Pitch 0.27 mm
Brightness 350 cd/m²
Contrast Ratio 1000:1 / 10000000:1 (dynamic)
Response Time 5 ms (grey-to-grey with overdrive)
Colour Gamut 99% sRGB, 85% DCI-P3
Input Connectors HDMI, 2xDisplayPort, USB-C
Display Position Adjustments Height, pivot (rotation), swivel, tilt
Screen Coating Anti-glare, 3H Hard Coating, Haze 25%
Voltage AC 120/230 V (50/60 Hz)
Colour Turbo silver
Dimensions (WxDxH) - with stand 53.17 cm x 19.5 cm x 52.14 cm
Weight 5.3 kg
Localisation English / United Kingdom
Environmental Standards TCO Certified Displays 8, TCO Certified Edge Displays, ENERGY STAR Qualified
Compliant Standards Plug and Play, VCCI, BSMI, GS, NOM, TUV S, WHQL, CB, CCC, PSB, FCC, ISO 9241-307, KCC, WEEE, cTUVus, China Energy Label Level 1, KC, ERP, CECP, CEL, EAC, ISC, SEPA, BIS, low halogen, DisplayPort 1.4, UAE, Ukraine Energy Label
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
£409.84
