We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
Experience extraordinary, precise color and see more of your projects at one time on a display with stunning 4K resolution.
Product Description | HP Z27 - LED monitor - 27" | Device Type | LED-backlit LCD monitor - 27" | Energy Class | Class G | Energy Consumption per Year | 62 kWh | Power Consumption (On mode) | 28 W | Features | USB 3.0 hub | Panel Type | IPS | Aspect Ratio | 16:9 | Native Resolution | 4K UHD (2160p) 3840 x 2160 at 60 Hz | Pixel Pitch | 0.1554 mm | Brightness | 350 cd/m² | Contrast Ratio | 1300:1 / 5000000:1 (dynamic) | Response Time | 8 ms (grey-to-grey) | Colour Support | 1024 grey levels (10-bit) | Colour Gamut | 100% BT.709, 99% sRGB | Input Connectors | HDMI, DisplayPort, Mini DisplayPort, USB-C | Display Position Adjustments | Height, pivot (rotation), swivel, tilt | Screen Coating | Anti-glare | Voltage | AC 120/230 V (50/60 Hz) | Colour | Black Pearl | Dimensions (WxDxH) - with stand | 61.41 cm x 23 cm x 50.98 cm | Weight | 9.38 kg | Localisation | English / United Kingdom | Environmental Standards | ENERGY STAR Qualified | Compliant Standards | Plug and Play, UL, VCCI, BSMI, GS, TUV S, WHQL, CB, CCC, PSB, FCC, ISO 9241-307, KCC, WEEE, KC, CECP, CEL, EAC, ISC, CEL Grade 2, SEPA, BIS, low halogen, ICE | Manufacturer Warranty | 3-year warranty |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 27" |
Built-in Devices | USB 3.0 hub |
Panel Type | IPS |
Pixel Per Inch | 163 |
Vertical Refresh Rate | 60 Hz |
Horizontal Refresh Rate | 135 kHz |
Horizontal Viewing Angle | 178 |
Vertical Viewing Angle | 178 |
Backlight Technology | LED backlight |
OSD Languages | Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Spanish, Dutch, Japanese |
Features | Picture by picture, HDCP, Frame Rate Control (FRC), Mercury free, Color Calibrated, Micro Edge, arsenic free, Picture-in-Picture, 99% sRGB colour gamut |
Dimensions (WxDxH) | 61.41 cm x 23 cm x 50.98 cm - with stand |
Weight | 9.38 kg |
Connectivity | |
Interfaces | HDMI (HDCP) , DisplayPort (HDCP) , USB-C upstream , Mini DisplayPort (HDCP) , USB-C downstream , Audio line-out , 3 x USB downstream (Type A) |
Mechanical | |
Tilt Angle | -5/+23 |
Swivel Angle | 90 |
Rotation Angle | 90 |
Height Adjustment | 150 mm |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately), detachable stand |
Cables Included | 1 x USB-C to USB-A cable - 1.8 m , 1 x DisplayPort cable - 1.8 m |
Backlight Life | 30,000 hours |
Security Slot Type | Kensington security slot |
Power | |
Input Voltage | AC 120/230 V (50/60 Hz) |
Power Consumption SDR (On mode) | 28 kWh/1000h |
Power Consumption (Typical) | 70 Watt |
Power Consumption Stand by | 0.5 Watt |
On / Off Switch | Yes |
Software / System Requirements | |
Included Software | HP Display Assistant |
Dimensions & Weight | |
Dimensions & Weight Details | With stand - width: 61.41 cm - depth: 23 cm - height: 50.98 cm - weight: 11.61 kg , Without stand - width: 61.41 cm - depth: 5.45 cm - height: 36.54 cm - weight: 6.21 kg |
Dimensions & Weight (Shipping) | |
Shipping Width | 72.4 cm |
Shipping Depth | 32.2 cm |
Shipping Height | 48 cm |
Environmental Standards | |
ENERGY STAR Certified | Yes |
ENERGY STAR Version | 7.0 |
Manufacturer Warranty | |
Service & Support | Limited warranty - parts and labour - 3 years |
Environmental Parameters | |
Min Operating Temperature | 5 °C |
Max Operating Temperature | 35 °C |
Humidity Range Operating | 20 - 80% (non-condensing) |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
