HP Z27 27" 3840x2160 8ms HDMI DP Mini DP USB-C LED Monitor
£544.48
28 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Optimize your workflows with a large, 4K display. View more lines of code, bigger spreadsheets, and vibrant colors, all with minimal toggling and scrolling.
  • Perfect your designs, projects, and documents on a display built to meet your demands. All HP Z Displays are rigorously tested and backed by an exclusive HP Zero Bright Dot Guarantee.
  • Work fast and clutter-free with USB-C™ connectivity that not only receives video and data from your device, but also delivers up to 65W of power—with just one cable.
  • Diagonal Size: 27in
  • Max Resolution: 3840 x 2160
  • Response Time: 8ms
  • Speakers: None
  • Interfaces: DisplayPort, HDMI, Mini DisplayPort, USB-C
Product codes
Bundle deals (1)
ANTIBACTERIAL WIPES
ANTIBACTERIAL WIPES
= £547.97
Save £1.50
Experience extraordinary, precise color and see more of your projects at one time on a display with stunning 4K resolution.
Product Description HP Z27 - LED monitor - 27"
Device Type LED-backlit LCD monitor - 27"
Energy Class Class B
Energy Consumption per Year 62 kWh
Power Consumption (On mode) 42 W
Features USB 3.0 hub
Panel Type IPS
Aspect Ratio 16:9
Native Resolution 4K UHD (2160p) 3840 x 2160 at 60 Hz
Pixel Pitch 0.1554 mm
Brightness 350 cd/m²
Contrast Ratio 1300:1 / 5000000:1 (dynamic)
Response Time 8 ms (grey-to-grey)
Colour Support 1024 grey levels (10-bit)
Input Connectors HDMI, DisplayPort, Mini DisplayPort, USB-C
Display Position Adjustments Height, pivot (rotation), swivel, tilt
Screen Coating Anti-glare
Colour Black Pearl
Dimensions (WxDxH) - with stand 61.41 cm x 23 cm x 50.98 cm
Weight 9.38 kg
Localisation English / United Kingdom
Environmental Standards TCO Certified Displays 8, ENERGY STAR Qualified
Compliant Standards Plug and Play, UL, VCCI, BSMI, GS, TUV S, WHQL, CB, CCC, PSB, FCC, ISO 9241-307, KCC, WEEE, KC, CECP, CEL, EAC, ISC, CEL Grade 2, SEPA, BIS, low halogen, ICE
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
HP Z27 27" 3840x2160 8...
£544.48
