HP Z27 27" 3840x2160 8ms HDMI DP Mini DP USB-C LED Monitor
£571.70
37 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Optimize your workflows with a large, 4K display. View more lines of code, bigger spreadsheets, and vibrant colors, all with minimal toggling and scrolling.
  • Perfect your designs, projects, and documents on a display built to meet your demands. All HP Z Displays are rigorously tested and backed by an exclusive HP Zero Bright Dot Guarantee.
  • Work fast and clutter-free with USB-Câ„¢ connectivity that not only receives video and data from your device, but also delivers up to 65W of power—with just one cable.
  • Diagonal Size: 27in
  • Max Resolution: 3840 x 2160
  • Response Time: 8ms
  • Speakers: None
  • Interfaces: DisplayPort, HDMI, Mini DisplayPort, USB-C
Product codes
Experience extraordinary, precise color and see more of your projects at one time on a display with stunning 4K resolution.
Product Description HP Z27 - LED monitor - 27"
Device Type LED-backlit LCD monitor - 27"
Energy Class Class B
Energy Consumption per Year 62 kWh
Power Consumption (On mode) 42 W
Features USB 3.0 hub
Panel Type IPS
Aspect Ratio 16:9
Native Resolution 4K UHD (2160p) 3840 x 2160 at 60 Hz
Pixel Pitch 0.1554 mm
Brightness 350 cd/m²
Contrast Ratio 1300:1 / 5000000:1 (dynamic)
Response Time 8 ms (grey-to-grey)
Colour Support 1024 grey levels (10-bit)
Input Connectors HDMI, DisplayPort, Mini DisplayPort, USB-C
Display Position Adjustments Height, pivot (rotation), swivel, tilt
Screen Coating Anti-glare
Colour Black Pearl
Dimensions (WxDxH) - with stand 61.41 cm x 23 cm x 50.98 cm
Weight 9.38 kg
Localisation English / United Kingdom
Environmental Standards TCO Certified Displays 7, TCO Certified Displays 8, ENERGY STAR Qualified
Compliant Standards Plug and Play, UL, VCCI, BSMI, GS, TUV S, WHQL, CB, CCC, PSB, FCC, ISO 9241-307, KCC, WEEE, KC, CECP, CEL, EAC, ISC, CEL Grade 2, SEPA, BIS, low halogen, ICE
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
HP Z27 27" 3840x2160 8...
£571.70
