We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
Meticulously crafted to surpass every design standard, the HP Z27k G3 4K USB-C Display is composed of authentic aluminum and delivers an impressive, frameless viewing experience. Bring your ideas to life with remarkable color accuracy in precise 4K resolution. Refine your work experience and transform your PC into a powerhouse with this 68.6 cm (27") diagonal screen monitor with USB-C 100W Power Delivery.
Product Description | HP Z27k G3 - LED monitor - 4K - 27" | Device Type | LED-backlit LCD monitor - 27" | Energy Class | Class G | Power Consumption (On mode) | 29.1 W | Features | USB 3.2 Gen 1 hub, USB PD 100 Watt | Panel Type | IPS | Aspect Ratio | 16:9 | Native Resolution | 4K 3840 x 2160 at 60 Hz | Pixel Pitch | 0.155 mm | Brightness | 350 cd/m² | Contrast Ratio | 1000:1 / 10000000:1 (dynamic) | Response Time | 5 ms (grey-to-grey with overdrive) | Colour Gamut | 99% sRGB | Input Connectors | HDMI, DisplayPort, USB-C | Display Position Adjustments | Height, pivot (rotation), swivel, tilt | Screen Coating | Anti-glare, 3H Hard Coating | Voltage | AC 120/230 V (50/60 Hz) | Dimensions (WxDxH) - with stand | 61.23 cm x 20.5 cm x 53.04 cm | Weight | 6.2 kg | Localisation | English / United Kingdom | Environmental Standards | TCO Certified Displays 8, TCO Certified Edge Displays, ENERGY STAR Qualified | Compliant Standards | VCCI, BSMI, GS, NOM, TUV S, CB, CCC, PSB, FCC, ISO 9241-307, KCC, WEEE, cTUVus, KC, CECP, CEL, EAC, SEPA, BIS, low halogen, UAE, Australian-New Zealand MEPS, Vietnam MEPS, Ukraine Energy Label |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 27" |
Built-in Devices | USB 3.2 Gen 1 hub |
USB Power Delivery | 100 Watt |
Panel Type | IPS |
Pixel Per Inch | 163 |
Vertical Refresh Rate | 50 - 60 Hz |
Horizontal Refresh Rate | 30 - 80 kHz |
Horizontal Viewing Angle | 178 |
Vertical Viewing Angle | 178 |
Backlight Technology | LED backlight |
Features | Low Blue Light Mode, Flicker Free technology, Mercury free, arsenic-free glass, 10-bit Colour Depth, edge-lit LED backlight, 4-sided micro-edge |
Dimensions (WxDxH) | 61.23 cm x 20.5 cm x 53.04 cm - with stand |
Weight | 6.2 kg |
Connectivity | |
Interfaces | DisplayPort 1.4 , 4 x USB 3.2 Gen 1 downstream , USB-C upstream/DisplayPort Alt Mode with Power Delivery (power up to 100W) , DisplayPort output , HDMI |
Mechanical | |
Tilt Angle | -5/+20 |
Swivel Angle | 90 |
Rotation Angle | 180 |
Height Adjustment | 150 mm |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately), detachable stand |
Included Accessories | VESA bracket |
Security Slot Type | Kensington security slot |
Power | |
Input Voltage | AC 120/230 V (50/60 Hz) |
Power Consumption SDR (On mode) | 29.1 kWh/1000h |
Power Consumption (Typical) | 42 Watt |
Power Consumption Stand by | 0.5 Watt |
Dimensions & Weight | |
Dimensions & Weight Details | With stand - width: 61.23 cm - depth: 20.5 cm - height: 53.04 cm - weight: 6.2 kg , Without stand - width: 61.23 cm - depth: 6.35 cm |
Dimensions & Weight (Shipping) | |
Shipping Width | 69.8 cm |
Shipping Depth | 42.3 cm |
Shipping Weight | 9.4 kg |
Environmental Standards | |
TCO Certified | TCO Certified Displays 8, TCO Certified Edge Displays |
ENERGY STAR Certified | Yes |
Environmental Parameters | |
Min Operating Temperature | 5 °C |
Max Operating Temperature | 35 °C |
Humidity Range Operating | 20 - 80% (non-condensing) |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
