HP Z27n 27" 2560x1440 14ms DVI HDMI DisplayPort QHD IPS...
HP Z27n 27" 2560x1440 14ms DVI HDMI DisplayPort QHD IPS LED Monitor
Key features
  • Connect to your everyday devices with integrated HDMI, mDP, DP, MHL, DVI, and a USB 3.0 hub with a fast-charging port. The DisplayPort output allows you to daisy chain up to two displays with just one PC or workstation connection.
  • Enjoy reliable color accuracy across all of your projects with a factory-calibrated 99% sRGB color gamut.
  • Get Quad HD visuals from a three-sided borderless design that reveals more of the screen.
Product codes
Enable a virtually borderless panorama of multiple displays with the HP Z27n narrow bezel IPS display, which has an edge-to-edge screen for maximum quad HD impact, out-of-the-box factory color calibration, and flexible connectivity for all of your devices.
Product Description HP Z27n - LED monitor - 27"
Device Type LED-backlit LCD monitor - 27"
Energy Class Class B
Energy Consumption per Year 55 kWh
Power Consumption (On mode) 37 W
Features USB 3.0 hub
Panel Type IPS
Aspect Ratio 16:9
Native Resolution QHD 2560 x 1440 at 60 Hz
Pixel Pitch 0.2331 mm
Brightness 350 cd/m²
Contrast Ratio 1000:1 / 5000000:1 (dynamic)
Response Time 14 ms (grey-to-grey), 8 ms (overdrive)
Colour Support 16.7 million colours
Input Connectors DVI-D, DisplayPort, Mini DisplayPort, HDMI (MHL)
Display Position Adjustments Height, pivot (rotation), swivel, tilt
Screen Coating Anti-glare
Colour Black
Dimensions (WxDxH) - with stand 61.43 cm x 21.82 cm x 53.37 cm
Weight 7.66 kg
Localisation English / United Kingdom
Microsoft Certification Compatible with Windows 7
Environmental Standards TCO Certified Displays 7, ENERGY STAR Qualified
Compliant Standards Plug and Play, UL, TUV GS, VCCI, C-Tick, BSMI, TUV S, WHQL, CB, CCC, TUV Ergo, FCC, KC, CECP, CEL Grade 2, SEPA
Manufacturer Warranty 5-year warranty
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
HP Z27n 27" 2560x1440...
