HP Z27N G2 27" 2560x1440 5.3ms DisplayPort HDMI DVI-D US...
HP Z27N G2 27" 2560x1440 5.3ms DisplayPort HDMI DVI-D USB-C LED Monitor
£335.98
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Consistent, accurate color between displays and from project to project is easier than ever with factory color calibration from the very first time you power on.
  • Get a clean, single USB-C™ cable video and data connection that’s ready for future generations of HP Workstations, plus multi-generation compatible VGA, HDMI, and DisplayPort™ and three USB 3.0.
  • Streamline multi-display multi-tasking with a 3-sided micro-edge and daisy chain up to 2 displays per workstation with DisplayPort™. Get stunning visuals from high resolution and over 3 million pixels.
  • We rigorously test every HP Z Display to help ensure its reliability and long life, and the stringent HP Zero Bright Dot Guarantee replaces the screen if even one bright sub-pixel fails.
  • Diagonal Size: 27in
  • Max Resolution: 2560 x 1440
  • Response Time: 5.3ms
  • Interfaces: DisplayPort, DVI, HDMI, USB-C
  • Stock Status: In Stock
Product codes
Be a productive powerhouse with the sleek QHD HP Z27n G2 68.58 cm (27") Display. This virtually seamless display is factory-tested for reliability and longevity with integrated color calibration, uninterrupted multi-screen tiling, and expansive device connections, including USB-C .
Product Description HP Z27n G2 - LED monitor - 27"
Device Type LED-backlit LCD monitor - 27"
Energy Class Class B
Energy Consumption per Year 53 kWh
Power Consumption (On mode) 36 W
Features USB 3.0/USB-C hub
Panel Type IPS
Aspect Ratio 16:9
Native Resolution QHD 2560 x 1440 at 60 Hz
Pixel Pitch 0.233 mm
Brightness 300 cd/m²
Contrast Ratio 1000:1 / 10000000:1 (dynamic)
Response Time 14 ms (default), 5.3 ms (grey-to-grey)
Colour Support 16.7 million colours
Input Connectors DisplayPort, HDMI, DVI-D, USB-C
Display Position Adjustments Height, pivot (rotation), swivel, tilt
Screen Coating Anti-glare, 3H Hard Coating
Colour Black Pearl
Dimensions (WxDxH) - with stand 61.3 cm x 21.4 cm x 50.9 cm
Weight 8 kg
Localisation English / United Kingdom
Environmental Standards ENERGY STAR Qualified
Compliant Standards Plug and Play, VCCI, BSMI, GS, TUV S, WHQL, CB, CCC, PSB, FCC, ISO 9241-307, WEEE, ICES, cTUVus, MEPS, TCO Certified Edge, E-Standby, KC, ERP, CEL Grade 1, ISC, RCM, MSIP, CEL Grade 2, SEPA, CoC, CU
Manufacturer Warranty 5-year warranty
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
HP Z27N G2 27" 2560x14...
£335.98
