HP Z27s 27" 3840x2160 6ms HDMI MHL DisplayPort UHD IPS L...
HP Z27s 27" 3840x2160 6ms HDMI MHL DisplayPort UHD IPS LED Monitor
Key features
  • Connect your display to a workstation, PC, and range of digital video devices with DisplayPort, mini-DisplayPort, HDMI, and four USB 3.0 ports. Use the two side-located USB ports for easy access to your most-used peripherals.
  • Enjoy massive 3840 x 2160 resolution, sRGB color gamut, and 1.07 billion colors for incredible color presentation of highly-detailed digital workflows. Wide viewing angles keep the line of sight open for one or many viewers.
  • Get expansive views of your projects, documents, and media with 8MP—4x that of a Full HD display. Picture-in-picture and picture-by-picture allow you to display mobile device, PC feeds and view up to four Full HD sources onscreen in native mode.
  • Instantly mirror your smart phone or tablet content to the large screen through an easy MHL connection that also keeps your devices charged and ready to go.
Product codes
Join the Ultra High Definition movement and expand your visual workspace with the HP Z27s 68,6 cm (27") IPS UHD Display, which delivers an extra-large screen with UHD/4K presentation and flexible connectivity and comfort features.
HP Z27s - LED monitor - 4K - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class C
Energy Consumption per Year
77 kWh
Power Consumption (On mode)
53 W
USB Hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
4K 3840 x 2160 at 60 Hz
Pixel Pitch
0.15525 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1 / 5000000:1 (dynamic)
Response Time
6 ms (grey-to-grey with overdrive)
Colour Support
1.07 billion colours
Input Connectors
HDMI, DisplayPort, Mini DisplayPort, MHL
Screen Coating
Anti-glare
62.56 cm x 24.24 cm x 53.59 cm
7.8 kg
English / United Kingdom
Plug and Play, VCCI, BSMI, NOM, TUV S, WHQL, CB, CCC, PSB, FCC, KCC, TCO Certified Edge, KC, CECP, EPA, ISC, CEL Grade 2, SEPA
3 years warranty
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
HP Z27s 27" 3840x2160...
