HP Z30i 30" 2560x1600 VGA DVI-D DisplayPort IPS Monitor
£1,346.95
Delivery:
Key features
  • Customize your workspace with resizable screen partitions. Work in documents, spreadsheets, and email in separate regions of the screen—at the same time—with HP Display Assistant software.
  • Enjoy future-ready and legacy connectivity from a range of inputs that include DisplayPort 1.2, DVI, VGA, HDMI 1.4, audio output for an HP Speaker Bar, and four USB 3.0 ports with speeds up to 10x faster than USB 2.0.
  • Find your most comfortable position with an HP-exclusive 4-way adjustable stand and an integrated HP QR2 Quick Release than enables VESA mounting.
  • Get organized with the integrated cable management clip. Create a clean, compact all-in-one with the optional HP Thin Client Mount Kit. The HP QR2 Quick Release is integrated into the display to enable quick set up, and it’s VESA mountable.
  • Lower your power consumption and get 100% coverage of sRGB color spaces and 99% coverage of Adobe RGB color spaces from IPS Gen 2 panels.
  • Diagonal Size: 30in
  • Max Resolution: 2560 x 1600
  • Response Time: 8ms
  • Speakers: None
  • Interfaces: DisplayPort, DVI, HDMI, VGA (HD-15)
Product codes
Get outstanding image accuracy, exceptional adjustability, and mission-critical reliability optimized for commercial environments. Built with IPS Gen 2 panels, the HP Z30i 76,2 cm (30') IPS Display delivers power savings over first-generation IPS technology and extra-wide viewing angles that foster collaboration.
Product Description HP Z30i - LED monitor - 30"
Device Type LED-backlit LCD monitor - 30"
Energy Class Class C
Energy Consumption per Year 97 kWh
Power Consumption (On mode) 66 W
Features USB 3.0 hub
Panel Type IPS2
Aspect Ratio 16:10
Native Resolution 2560 x 1600 at 60 Hz
Pixel Pitch 0.25 mm
Brightness 350 cd/m²
Contrast Ratio 1000:1 / 5000000:1 (dynamic)
Response Time 8 ms (grey-to-grey)
Input Connectors HDMI, DVI-I, VGA, DisplayPort
Display Position Adjustments Height, pivot (rotation), swivel, tilt
Screen Coating Anti-glare
Colour Black
Dimensions (WxDxH) - with stand 69.03 cm x 26.64 cm x 60.1 cm
Weight 9.96 kg
Localisation English / United Kingdom
Environmental Standards ENERGY STAR Qualified
Compliant Standards Plug and Play, VCCI, NOM, TUV S, WHQL, CB, CCC, PSB, FCC, KCC, TCO Certified Edge, KC, CECP, EPA, CEL Grade 1
Manufacturer Warranty 5-year warranty
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
HP Z30i 30" 2560x1600...
£1,346.95
