Experience extraordinary, precise color and see more of your projects at one time on a display with stunning 4K resolution.
Product Description | HP Z32 - LED monitor - 4K - 31.5" | Device Type | LED-backlit LCD monitor - 31.5" | Energy Class | Class G | Energy Consumption per Year | 66 kWh | Power Consumption (On mode) | 33 W | Features | USB 3.0/USB-C hub | Panel Type | IPS | Aspect Ratio | 16:9 | Native Resolution | 4K 3840 x 2160 at 60 Hz | Pixel Pitch | 0.181 mm | Brightness | 350 cd/m² | Contrast Ratio | 1300:1 / 5000000:1 (dynamic) | Response Time | 14 ms (grey-to-grey) | Colour Gamut | 100% BT.709, 99% sRGB | Input Connectors | HDMI, DisplayPort, Mini DisplayPort, USB-C | Display Position Adjustments | Height, pivot (rotation), swivel, tilt | Screen Coating | Anti-glare | Voltage | AC 120/230 V (50/60 Hz) | Colour | Black | Dimensions (WxDxH) - with stand | 71.45 cm x 24.8 cm x 56.44 cm | Weight | 12.16 kg | Localisation | English / United Kingdom | Environmental Standards | TCO Certified Displays 8, ENERGY STAR Qualified | Compliant Standards | VCCI, BSMI, NOM, TUV S, WHQL, CB, CCC, PSB, ISO 9241-307, KCC, WEEE, MEPS, KC, CECP, CEL, EAC, ISC, SEPA, low halogen, ICE | Manufacturer Warranty | 5-year warranty |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 31.5" |
Built-in Devices | USB 3.0/USB-C hub |
Panel Type | IPS |
Pixel Per Inch | 140 |
Vertical Refresh Rate | 29 - 60 Hz |
Horizontal Refresh Rate | 28 - 135 kHz |
Horizontal Viewing Angle | 178 |
Vertical Viewing Angle | 178 |
Backlight Technology | WLED |
Features | HDCP, anti-glare, Mercury free, arsenic-free glass, 99% sRGB colour gamut |
Colour | Black |
Dimensions (WxDxH) | 71.45 cm x 24.8 cm x 56.44 cm - with stand |
Weight | 12.16 kg |
Connectivity | |
Interfaces | DisplayPort , Mini DisplayPort , HDMI , Audio line-out , 3 x USB 3.0 downstream , USB-C upstream , USB-C downstream |
Mechanical | |
Tilt Angle | -5/+20 |
Swivel Angle | 90 |
Height Adjustment | 120 mm |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately) |
Cables Included | 1 x USB cable - 1.8 m , 1 x DisplayPort cable - 1.8 m |
Backlight Life | 30,000 hours |
Security Slot Type | Kensington security slot |
Power | |
Input Voltage | AC 120/230 V (50/60 Hz) |
Power Consumption SDR (On mode) | 33 kWh/1000h |
Power Consumption (Typical) | 70 Watt |
Power Consumption Stand by | 0.5 Watt |
Software / System Requirements | |
Included Software | HP Display Assistant |
Dimensions & Weight | |
Dimensions & Weight Details | With stand - width: 71.45 cm - depth: 24.8 cm - height: 56.44 cm - weight: 12.16 kg , Without stand - width: 71.45 cm - depth: 4.45 cm - height: 41.09 cm - weight: 7.59 kg |
Environmental Standards | |
TCO Certified | TCO Certified Displays 8 |
ENERGY STAR Certified | Yes |
Manufacturer Warranty | |
Service & Support | Limited warranty - 5 years - on-site - response time: next business day |
Environmental Parameters | |
Min Operating Temperature | 5 °C |
Max Operating Temperature | 35 °C |
Humidity Range Operating | 20 - 80% (non-condensing) |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
