We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
Completely immerse yourself in the expansive elegance of the HP Z38c Curved Display. Form meets function with crisp, panoramic views so you can stay focused on your work.
Product Description | HP Z38c - LED monitor - curved - 37.5" | Device Type | LED-backlit LCD monitor - 37.5" | Energy Class | Class G | Energy Consumption per Year | 93 kWh | Power Consumption (On mode) | 64 W | Curved Screen | Yes | Features | USB-C hub | Panel Type | IPS | Aspect Ratio | 21:9 | Native Resolution | UWQHD+ 3840 x 1600 at 60 Hz | Pixel Pitch | 0.229 mm | Brightness | 300 cd/m² | Contrast Ratio | 1000:1 / 5000000:1 (dynamic) | Response Time | 14 ms (grey-to-grey), 5 ms (grey-to-grey with overdrive) | Colour Support | 1.07 billion colours | Colour Gamut | 98% | Input Connectors | HDMI, DisplayPort, USB-C | Display Position Adjustments | Height, swivel, tilt | Screen Coating | Anti-glare, 3H Hard Coating | Voltage | AC 120/230 V (50/60 Hz) | Colour | Black | Dimensions (WxDxH) - with stand | 89.55 cm x 24.8 cm x 55.87 cm | Weight | 13.8 kg | Localisation | English / United Kingdom | Compliant Standards | Plug and Play, VCCI, BSMI, TUV S, WHQL, CB, CCC, PSB, FCC, ISO 9241-307, WEEE, ICES, cTUVus, MEPS, KC, CECP, EAC, ISC, MSIP, SEPA, BIS, CoC |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 37.5" |
Curved Screen | Yes (2300R) |
Built-in Devices | USB-C hub |
Panel Type | IPS |
Pixel Per Inch | 110.93 |
Vertical Refresh Rate | 24 - 76 Hz |
Horizontal Refresh Rate | 27 - 130 kHz |
Horizontal Viewing Angle | 178 |
Vertical Viewing Angle | 178 |
Backlight Technology | WLED |
OSD Languages | Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Spanish, Dutch, Japanese |
Features | HDCP, Micro Edge |
Colour | Black |
Dimensions (WxDxH) | 89.55 cm x 24.8 cm x 55.87 cm - with stand |
Weight | 13.8 kg |
Connectivity | |
Interfaces | HDMI (HDCP) , USB-C (HDCP) , DisplayPort (HDCP) , 2 x USB downstream , 3 x USB 3.0 downstream , Audio line-out , USB downstream , USB-C upstream |
Mechanical | |
Tilt Angle | -5/+20 |
Swivel Angle | 90 |
Height Adjustment | 120 mm |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately), detachable stand |
Cables Included | 1 x DisplayPort cable , 1 x HDMI cable , 1 x USB-C cable |
Backlight Life | 30,000 hours |
Power | |
Input Voltage | AC 120/230 V (50/60 Hz) |
Power Consumption SDR (On mode) | 64 kWh/1000h |
Power Consumption (Typical) | 80 Watt |
Power Consumption Stand by | 0.5 Watt |
On / Off Switch | Yes |
Software / System Requirements | |
Included Software | HP Display Assistant |
Dimensions & Weight | |
Dimensions & Weight Details | With stand - width: 89.55 cm - depth: 24.8 cm - height: 55.87 cm - weight: 13.8 kg , Without stand - width: 89.55 cm - depth: 10.42 cm - height: 39.95 cm - weight: 9.8 kg |
Environmental Parameters | |
Min Operating Temperature | 5 °C |
Max Operating Temperature | 35 °C |
Humidity Range Operating | 20 - 80% (non-condensing) |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
