HP Z38c 37.5" 3840x1600 5ms HDMI DisplayPort USB-C Curve...
HP Z38c 37.5" 3840x1600 5ms HDMI DisplayPort USB-C Curved IPS LED Monitor
£1,069.63
Delivery:
Key features
  • Comfortably view your work on the 95.25 cm (37.5") diagonal curve. Feel the immersion with a 2300 mm radius that fits your natural field of vision. It's the sweet spot for day-in, day-out use.
  • See every facet of your creation in crystal-clear 4K-wide, 3840x1600 resolution. With optimized pixel density your icons and text are the ideal size.
  • See your entire project without the distracting bezels in the middle of a dual display setup. One large viewing area keeps you more productive when working in multiple applications.
Product codes
Completely immerse yourself in the expansive elegance of the HP Z38c Curved Display. Form meets function with crisp, panoramic views so you can stay focused on your work.
Product Description HP Z38c - LED monitor - curved - 37.5"
Device Type LED-backlit LCD monitor - 37.5"
Energy Class Class B
Energy Consumption per Year 93 kWh
Power Consumption (On mode) 64 W
Curved Screen Yes
Features USB-C hub
Panel Type IPS
Aspect Ratio 21:9
Native Resolution UWQHD+ 3840 x 1600 at 60 Hz
Pixel Pitch 0.229 mm
Brightness 300 cd/m²
Contrast Ratio 1000:1 / 5000000:1 (dynamic)
Response Time 14 ms (grey-to-grey); 5 ms (grey-to-grey with overdrive)
Colour Support 1.07 billion colours
Input Connectors HDMI, DisplayPort, USB-C
Display Position Adjustments Height, swivel, tilt
Screen Coating Anti-glare, 3H Hard Coating
Colour Black
Dimensions (WxDxH) - with stand 89.55 cm x 24.8 cm x 55.87 cm
Weight 13.8 kg
Localisation English / United Kingdom
Compliant Standards Plug and Play, VCCI, BSMI, TUV S, WHQL, CB, CCC, PSB, FCC, ISO 9241-307, WEEE, ICES, cTUVus, MEPS, KC, CECP, EAC, ISC, MSIP, SEPA, BIS, CoC
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
HP Z38c 37.5" 3840x160...
£1,069.63
