We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
Upgrade your impromptu meetings and collaborative brainstorming sessions with the 107.97 cm (42.51") diagonal HP Z43 4K UHD Display. Get started immediately with single USB-C cable connectivity to your devices.
Product Description | HP Z43 - LED monitor - 4K - 42.5" | Device Type | LED-backlit LCD monitor - 42.5" | Energy Class | Class G | Power Consumption (On mode) | 64 W | Features | USB 3.0 hub, USB-C hub | Panel Type | IPS | Aspect Ratio | 16:9 | Native Resolution | 4K 3840 x 2160 at 60 Hz | Pixel Pitch | 0.2451 mm | Brightness | 350 cd/m² | Contrast Ratio | 1000:1 / 5000000:1 (dynamic) | Response Time | 5 ms (grey-to-grey) | Colour Gamut | 72% NTSC, 96% sRGB | Input Connectors | HDMI, DisplayPort, Mini DisplayPort, USB-C | Display Position Adjustments | Swivel, tilt | Screen Coating | Anti-glare | Voltage | AC 120/230 V (50/60 Hz) | Colour | Black Pearl | Dimensions (WxDxH) - with stand | 97.21 cm x 24 cm x 61.9 cm | Weight | 16.95 kg | Localisation | English / United Kingdom | Environmental Standards | ENERGY STAR Qualified | Compliant Standards | Plug and Play, UL, VCCI, BSMI, TUV S, WHQL, CB, CCC, PSB, FCC, ISO 9241-307, KCC, WEEE, KC, CECP, EAC, CEL Grade 1, ISC, SEPA, low halogen, ICE | Manufacturer Warranty | 3-year warranty |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 42.5" |
Built-in Devices | USB 3.0 hub, USB-C hub |
Panel Type | IPS |
Vertical Refresh Rate | 47 - 63 Hz |
Horizontal Refresh Rate | 121.8 - 140 kHz |
Horizontal Viewing Angle | 178 |
Vertical Viewing Angle | 178 |
Backlight Technology | LED backlight |
Colour Temperature | 10000K |
Features | Picture by picture, HDCP, Mercury free, arsenic-free glass, Zero Bright Dot Warranty, Picture-in-Picture, 72% NTSC colour gamut |
Dimensions (WxDxH) | 97.21 cm x 24 cm x 61.9 cm - with stand |
Weight | 16.95 kg |
Connectivity | |
Interfaces | DisplayPort (HDCP) , Mini DisplayPort , HDMI (HDCP) , USB-C upstream/DisplayPort Alt Mode , USB-C downstream , USB 3.0 upstream , 4 x USB 3.0 downstream , Audio line-out |
Mechanical | |
Tilt Angle | -5/+10 |
Swivel Angle | 20 |
VESA Mounting Interface | 100 x 100 mm, 200 x 200 mm |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately) |
Cables Included | 1 x USB-C to USB-A cable - 1.8 m , 1 x DisplayPort cable - 1.8 m |
Backlight Life | 30,000 hours |
Power | |
Input Voltage | AC 120/230 V (50/60 Hz) |
Power Consumption SDR (On mode) | 64 kWh/1000h |
Power Consumption (Typical) | 95 Watt |
Software / System Requirements | |
Included Software | HP Display Assistant |
OS Required | Microsoft Windows 7, Windows 8, Windows 8.1, Windows 10 |
Dimensions & Weight | |
Dimensions & Weight Details | With stand - width: 97.21 cm - depth: 24 cm - height: 61.9 cm - weight: 16.95 kg , Without stand - width: 97.21 cm - depth: 12.28 cm - height: 56.59 cm - weight: 12.45 kg |
Dimensions & Weight (Shipping) | |
Shipping Width | 112 cm |
Shipping Depth | 70 cm |
Shipping Height | 36 cm |
Shipping Weight | 23.47 kg |
Environmental Standards | |
ENERGY STAR Certified | Yes |
Manufacturer Warranty | |
Service & Support | Limited warranty - parts and labour - 3 years |
Environmental Parameters | |
Min Operating Temperature | 5 °C |
Max Operating Temperature | 35 °C |
Humidity Range Operating | 20 - 80% (non-condensing) |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
