HP Z440 ZE3.5 E5 16GB 256GB W8.1/7P
£2,195.68
Delivery:
Key features
  • Protect your investment today with HP’s legendary reliability and standardize on a long-life cycle configuration.
  • Quickly cross items off your to-do list and achieve massive computational performance with a single processor. Experience lightning-fast performance in a workstation that never slows you down.
  • When your job requires more, HP makes it easy.
Product codes
Take your business to the next level of performance, expandability, and no compromise reliability in one complete package. Featuring a perfect mix of HP Z DNA in a performance workstation package with up to 8 discrete processor cores, up to 128 GB of RAM, and multiple storage and PCIe configuration options.
Get the job done fast
Cross items off your to-do list fast. Achieve massive computational performance with a single processor personal workstation delivering support for up to 8 cores of processing power. Add in powerful graphics and performance features like optional Thunderbolt 2, HP Z Turbo Drive, and HP Remote Graphics Software, and you get a world-class workstation experience that never slows you down.
Customize it to grow with you
When your job requires more, the HP Z440 Workstation, with its sleek 4U form factor, tool-less design, and built in handles make it simple to expand. Easily configure memory, storage, graphics, and more to suit your needs.
Position for the future
Protect your investment and make downtime a thing of the past. Get no-compromise reliability and a standard 3/3/3 limited warranty from the HP Z440 Workstation.
Product Description HP Workstation Z440 - MT - Xeon E5-1620V3 3.5 GHz - 16 GB - 2.256 TB - UK layout
Type Workstation - mini tower
Platform Technology Intel vPro Technology
Height (Rack Units) 4U
Localisation Language: English / region: United Kingdom
Processor 1 x Intel Xeon E5-1620V3 / 3.5 GHz (3.6 GHz) (Quad-Core)
Processor Socket LGA2011-v3 Socket
Processor Main Features Hyper-Threading Technology, Intel Turbo Boost Technology 2
Cache Memory 10 MB
Cache Per Processor 10 MB
RAM 16 GB (installed) / 128 GB (max) - DDR4 SDRAM - ECC - PC4-17000
Storage Controller SATA (SATA 6Gb/s)
Hard Drive 1 x 2 TB - SATA 6Gb/s - 7200 rpm
Hard Drive (2nd) 1 x SSD 256 GB - SATA 6Gb/s
Optical Storage DVD SuperMulti
Graphics Controller PCIe 3.0 x16 - AMD FirePro W5100
Video Memory 4 GB GDDR5 SDRAM
Networking GigE
Power AC 120/230 V (50/60 Hz)
OS Provided Microsoft Windows 7 Professional 64-bit Edition (downgrade from Windows 8.1 Pro 64-bit) + Windows 8.1 Pro 64-bit Licence
Dimensions (WxDxH) 16.891 cm x 44.47 cm x 43.18 cm
Weight 11 kg
Manufacturer Warranty Limited warranty - parts and labour - 3 years - on-site
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
HP Z440 ZE3.5 E5 16GB...
£2,195.68
