Take your business to the next level of performance, expandability, and no compromise reliability in one complete package. Featuring a perfect mix of HP Z DNA in a performance workstation package with up to 8 discrete processor cores, up to 128 GB of RAM, and multiple storage and PCIe configuration options.
Get the job done fast
Cross items off your to-do list fast. Achieve massive computational performance with a single processor personal workstation delivering support for up to 8 cores of processing power. Add in powerful graphics and performance features like optional Thunderbolt 2, HP Z Turbo Drive, and HP Remote Graphics Software, and you get a world-class workstation experience that never slows you down.
Customize it to grow with you
When your job requires more, the HP Z440 Workstation, with its sleek 4U form factor, tool-less design, and built in handles make it simple to expand. Easily configure memory, storage, graphics, and more to suit your needs.
Position for the future
Protect your investment and make downtime a thing of the past. Get no-compromise reliability and a standard 3/3/3 limited warranty from the HP Z440 Workstation.
Product Description | HP Workstation Z440 - MT - Xeon E5-1620V3 3.5 GHz - 16 GB - 2.256 TB - UK | Type | Workstation - mini tower | Platform Technology | Intel vPro Technology | Height (Rack Units) | 4U | Localisation | Language: English / region: United Kingdom | Processor | 1 x Intel Xeon E5-1620V3 / 3.5 GHz (3.6 GHz) (Quad-Core) | Processor Socket | LGA2011-v3 Socket | Processor Main Features | Hyper-Threading Technology, Intel Turbo Boost Technology 2 | Cache Memory | 10 MB | Cache Per Processor | 10 MB | RAM | 16 GB (installed) / 128 GB (max) - DDR4 SDRAM - ECC - PC4-17000 | Storage Controller | SATA (SATA 6Gb/s) | Hard Drive | 1 x 2 TB - SATA 6Gb/s - 7200 rpm | Hard Drive (2nd) | 1 x SSD 256 GB - SATA 6Gb/s | Optical Storage | DVD SuperMulti | Graphics Controller | PCIe 3.0 x16 - AMD FirePro W5100 | Video Memory | 4 GB GDDR5 SDRAM | Networking | GigE | Keyboard | UK | Power | AC 120/230 V (50/60 Hz) | OS Provided | Microsoft Windows 7 Professional 64-bit Edition (downgrade from Windows 8.1 Pro 64-bit) + Windows 8.1 Pro 64-bit Licence | Colour | Jack black | Dimensions (WxDxH) | 16.891 cm x 44.47 cm x 43.18 cm | Weight | 11 kg | Manufacturer Warranty | Limited warranty - parts and labour - 3 years - on-site |
General | |
Type | Workstation |
Product Form Factor | Mini tower - 4U |
Built-in Devices | Speaker, solenoid hood lock |
Embedded Security | Trusted Platform Module (TPM 1.2) Security Chip |
Processor / Chipset | |
CPU | Intel Xeon E5-1620V3 / 3.5 GHz |
Max Turbo Speed | 3.6 GHz |
Number of Cores | Quad-Core |
CPU Qty | 1 |
Max CPU Qty | 1 |
CPU Upgradability | Upgradable |
CPU Socket | LGA2011-v3 Socket |
Chipset Type | Intel C612 |
Cache Memory | |
Installed Size | 10 MB |
RAM | |
Installed Size | 16 GB / 128 GB (max) |
Technology | DDR4 SDRAM - ECC |
Effective Memory Speed | 2133 MHz |
Rated Memory Speed | 2133 MHz |
Memory Specification Compliance | PC4-17000 |
Form Factor | DIMM 288-pin |
Slots | 8 (Total) / 4 (empty) |
Features | Registered |
Configuration Features | 4 x 4 GB |
Hard Drive | |
Type | HDD |
Capacity | 1 x 2 TB |
Interface Type | SATA 6Gb/s |
Spindle Speed | 7200 rpm |
Hard Drive (2nd) | |
Type | SSD |
Interface Class | Serial ATA |
Capacity | 1 x 256 GB |
Storage Controller | |
Type | 1 x SATA |
Controller Interface Type | SATA 6Gb/s |
RAID Level | RAID 0, RAID 1, RAID 10 |
Optical Storage | |
Type | DVD SuperMulti - SATA |
Monitor | |
Monitor Type | None. |
Graphics Controller | |
Interface Type | PCIe 3.0 x16 |
Graphics Processor | AMD FirePro W5100 |
Video Interfaces | DisplayPort |
Audio Output | |
Compliant Standards | High Definition Audio |
Input Device | |
Type | Mouse, keyboard |
Keyboard | |
Interface | USB |
Localization & Layout | UK |
Mouse | |
Technology | Optical |
Interface | USB |
Networking | |
Interface (Bus) Type | PCI Express 1.1 x1 |
Ethernet Controller | Intel I218-LM |
Data Link Protocol | Ethernet, Fast Ethernet, Gigabit Ethernet |
Features | Wake on LAN (WoL), PXE support, auto-uplink (auto MDI/MDI-X) |
Compliant Standards | IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.3z, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.1as, IEEE 802.3az |
Expansion / Connectivity | |
Bays | 1 (total) / 0 (free) x external 5.25" Slim Line , 2 (total) / 2 (free) x external 5.25" , 2 (total) / 0 (free) x internal 3.5" |
Slots | 8 (total) / 4 (free) x DIMM 288-pin , 1 (total) / 0 (free) x CPU , 1 (total) / 1 (free) x PCIe 2.0 x1 - half-length, full-height , 2 (total) / 1 (free) x PCIe 3.0 x16 - full-length, full-height , 1 (total) / 1 (free) x PCIe 2.0 x4 - full-length, full-height , 1 (total) / 1 (free) x PCIe 3.0 x8 - full-length, full-height , 1 (total) / 1 (free) x PCI - full-length, full-height |
Interfaces | 8 x USB 3.0 (4 front, 4 rear) , 1 x headphones (1 in front) , 1 x microphone (1 in front) , 1 x audio line-in , 1 x audio line-out , 2 x USB 2.0 , 1 x PS/2 keyboard , 1 x PS/2 mouse , 1 x LAN (Gigabit Ethernet) , 4 x DisplayPort |
Miscellaneous | |
Features | Power-on password, USB port control, audio ports control, network port control, Setup Password |
Theft/Intrusion Protection | Security lock slot (cable lock sold separately) |
Security Slot Type | Kensington security slot |
Compliant Standards | ACPI, RoHS, WEEE |
Power | |
Device Type | Power supply |
Nominal Voltage | AC 120/230 V (50/60 Hz) |
Power Provided | 700 Watt |
80 PLUS Certification | 80 PLUS |
Power Factor Correction | Yes (active) |
Operating System / Software | |
OS Provided | Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 8.1 Pro 64-bit) + Windows 8.1 Pro 64-bit Licence - English |
Manufacturer Warranty | |
Service & Support | Limited warranty - parts and labour - 3 years - on-site |
Dimensions & Weight | |
Width | 16.891 cm |
Depth | 44.47 cm |
Height | 43.18 cm |
Weight | 11 kg |
Environmental Parameters | |
Min Operating Temperature | 5 °C |
Max Operating Temperature | 35 °C |
Humidity Range Operating | 8 - 85% (non-condensing) |
