HP ZBook 14u G5 Core i7-8550U 16GB 256GB SSD 14" Windows...
£2,113.78
Hurry, only 1 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • Keep your files and privacy safe while traveling. Optional HP Sure View guards your screen from prying eyes & HP Sure Click protects web browsing with hardware-enforced security.
  • Our redesigned ZBook has been customized for road warriors with metallic finishes, and an optional 4K, touch display display that starts at just 1.48 kg and 17.9 mm thin.
  • Power through your day using everything from spreadsheets to CAD with blazing fast HP Z Turbo Drive high speed storage and certified AMD Radeon™ Pro graphics.
  • Display Size: 14in
  • Processor Model: I7-8550U
  • Operating System: Windows 10 Pro 64-bit Edition
  • Installed Memory: 16GB
  • Hard Drive Capacity: 256GB
Product codes
Finally, workstation-class power meets thin and light design for executives on-the-go. With advanced features like quad core Intel Core processors and 3D professional graphics, you can view and edit high resolution files from anywhere.
Product Description HP ZBook 14u G5 Mobile Workstation - 14" - Core i7 8550U - 16 GB RAM - 256 GB SSD - UK
Product Type Notebook
Operating System Win 10 Pro 64-bit - English
Processor Intel Core i7 (8th Gen) 8550U / 1.8 GHz (4 GHz) / 8 MB Cache
Memory 16 GB DDR4 (1 x 16 GB)
Storage 256 GB SSD NVMe
Optical Drive No optical drive
Display 14" LED backlight 1920 x 1080 / Full HD
Graphics AMD Radeon Pro WX 3100 / Intel HD Graphics 620
Video Memory 2 GB
Input Device Pointing stick, ClickPad
Keyboard UK
Keyboard Backlight Yes
Integrated Webcam Yes
Networking 802.11a/b/g/n/ac, Bluetooth 4.2, Gigabit Ethernet
Battery 3-cell - up to 10 hours
Dockable Yes
Security Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader, smart card reader
Colour Turbo silver
Dimensions (WxDxH) 32.6 cm x 23.43 cm x 1.79 cm
Weight 1.48 kg
Localisation Language: English / region: United Kingdom
Manufacturer Warranty Limited warranty - parts and labour - 3 years - on-site - response time: next business day
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
HP ZBook 14u G5 Core i...
£2,113.78
