HP Zbook 15 G5 Core i7-8850H 4GB 1TB 15" Windows 10 Pro
Key features
  • Boost your speed on single and multi-threaded apps with the high-performance multi-core Intel processor. Through it all, our cutting-edge thermal design keeps everything cool and quiet.
  • System safeguards like HP Client Security Suite and HP Sure Start - the industry’s first self-healing BIOS - mean your device is locked down tight, so your data and identity are too.
  • When your technology needs evolve, you can easily upgrade. Simply remove the back panel and switch out your memory or storage in seconds.
Product codes
Get extraordinary performance with industry-leading security packed into a mobile workstation designed to thrive with heavy rendering, engineering and simulation workflows.
Product Description HP ZBook 15 G5 Mobile Workstation - 15.6" - Core i7 8750H - 8 GB RAM - 1 TB HDD - UK
Product Type Notebook
Operating System Win 10 Pro 64-bit - English
Processor Intel Core i7 (8th Gen) 8750H / 2.2 GHz (4.1 GHz) / 9 MB Cache
Memory 8 GB DDR4 (1 x 8 GB)
Storage 1 TB HDD / 7200 rpm + 16 GB SSD cache (M.2) (3D Xpoint (Optane))
Optical Drive No optical drive
Display 15.6" LED backlight 1920 x 1080 / Full HD
Graphics NVIDIA Quadro P1000 / Intel UHD Graphics 630
Video Memory 4 GB GDDR5 SDRAM
Input Device Pointing stick, ClickPad
Keyboard UK
Keyboard Backlight Yes
Numeric Keypad Yes
Networking 802.11a/b/g/n/ac, Bluetooth 5.0, Gigabit Ethernet
Battery 4-cell
Security Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader, smart card reader
Colour Turbo silver
Dimensions (WxDxH) 37.6 cm x 26.4 cm x 2.6 cm
Weight 2.6 kg
Localisation Language: English / region: United Kingdom
Manufacturer Warranty Limited warranty - parts and labour - 3 years
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
HP Zbook 15 G5 Core i7...
